Re: Thermostat stuck question
[Re: dodgeboychris]
#173477
12/23/08 03:26 PM
12/23/08 03:26 PM
RapidRobert
Tstat would be a likely suspect. I would for sure open it up & check it out & go from there
[Re: crlush]
#173481
12/25/08 09:33 PM
12/25/08 09:33 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
I've had thermostats stick open (90 Dakota) and closed (78 Magnum), so it does happen, they are not generally high quality pieces. But both of these happened in moderate temps. Your's seems suspicious given the cold temps. What did you find?
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
