Thermostat stuck question #173475
12/23/08 02:56 PM
12/23/08 02:56 PM
IA. ,USA
dodgeboychris Offline OP
IA. ,USA
Sunday night on my way home from work (-5 degrees) my car overheated, stopped at gas station and let cool down for half hour and added premixed antifreeze (1/2 gallon) most of what was lost got puked out overflow jug. my question is do I have to change that thermostat or can I get lucky and just fill it back up and go?
Re: Thermostat stuck question [Re: dodgeboychris] #173476
12/23/08 03:19 PM
12/23/08 03:19 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
First things first. Is it a bad thermostat or did you just jump in and start driving without letting it warm up first? You need to remember that the air over the radiator is a lot colder then the outside temp. It could be you just froze the coolant which my have been thinned out some.
Re: Thermostat stuck question [Re: dodgeboychris] #173477
12/23/08 03:26 PM
12/23/08 03:26 PM
Tstat would be a likely suspect. I would for sure open it up & check it out & go from there
Re: Thermostat stuck question [Re: dodgeboychris] #173478
12/23/08 03:33 PM
12/23/08 03:33 PM
IA. ,USA
IA. ,USA
I did let it warm for a short while , but not all the way. I'm going out now to look at it 30 degrees now.
Re: Thermostat stuck question [Re: dodgeboychris] #173479
12/23/08 03:58 PM
12/23/08 03:58 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I am betting that you froze the coolant up. Stats sticking is rare. Sure what blew out was liquid but the coolant crystalized and couldn't flow.
Re: Thermostat stuck question [Re: dodgeboychris] #173480
12/24/08 04:06 PM
12/24/08 04:06 PM
crlush Offline
crlush  Offline
if its cold enough and the antifreeze is watered down some it will freeze up while driving. had it happen to me sometime ago stopped for a while till it thawed then drove allitle slower till it warmed up then it was fine, just added some more antifreeze. hope this helps
Re: Thermostat stuck question [Re: crlush] #173481
12/25/08 09:33 PM
12/25/08 09:33 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I've had thermostats stick open (90 Dakota) and closed (78 Magnum), so it does happen, they are not generally high quality pieces. But both of these happened in moderate temps. Your's seems suspicious given the cold temps. What did you find?
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
