70-73 A body Sun visors/rear view #1734644
01/19/15 10:57 PM
01/19/15 10:57 PM
Hershey, PA
73MagDuster Offline OP
Hershey, PA
I have a 73 Duster. I have no inside rear view mirror or sunvisors. I have seen visor with tips that snap into the rear view mirror base, but was told that was only for 70-71 cars. Can someone school me on what years had what and if 73 did not have the tipped visors can I put the tipped visors in if I put the earlier rear view mirror in as well?
Thanks!
Re: 70-73 A body Sun visors/rear view [Re: 73MagDuster] #1734645
01/20/15 01:37 AM
01/20/15 01:37 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I can't tell you when they changed (about 73 sounds right), Mopar put in shorter sun visors that were only supported at the door edges. I believe the mounting holes for the visors and the rear view mirrors remained unchanged, in which case you could just mount the older visors & mirror. I suppose in the worse case, you might have to drill new screw holes.
I don't believe you can swap the visors across the body lines though, your A body will need to have A body visors. The length of the visors, and the angle of the mounting pad changed between bodies and when they came out with the glued to the windshield mirrors, lots of stuff changed. Gene
Re: 70-73 A body Sun visors/rear view [Re: poorboy] #1734646
01/20/15 03:03 PM
01/20/15 03:03 PM
Hershey, PA
Hershey, PA
Thanks Gene, I was hoping that was the case.
