YEAR ONE WIRING HARNESS..... #173461
12/23/08 01:59 PM
12/23/08 01:59 PM
NW Ohio
6pkaar Offline OP
6pkaar  Offline OP
NW Ohio
Yhe "modified" engine harness Year One sells for adding electronic ignition for a '70 'Cuda.....where do they have that set up to mount the ECU? I'd like to put it under the dash so the engine bay still looks like a 1970.
Re: YEAR ONE WIRING HARNESS..... [Re: 6pkaar] #173462
12/24/08 08:26 AM
12/24/08 08:26 AM
Newfoundland
Crocker Offline
Crocker  Offline
Newfoundland
Next to the voltage regulator. It is the same as the later e bodies with the 4 pin ballast resisitor
Re: YEAR ONE WIRING HARNESS..... [Re: Crocker] #173463
12/24/08 01:57 PM
12/24/08 01:57 PM
Virginia
67 GTX Offline
67 GTX  Offline
Virginia
Those harnesses are also set up for a dual field alternator.
Re: YEAR ONE WIRING HARNESS..... [Re: 67 GTX] #173464
12/24/08 02:14 PM
12/24/08 02:14 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
didn't all 70s have that?
