2011 Ram 1500 5.7L won't go into gear? #1734324
01/19/15 03:43 PM
01/19/15 03:43 PM
Morningside
AdventurerSport Offline OP
waaaay out there in left field
Morningside
What's up with my 2011 Ram? 70K miles, suddenly this morning it won't go into gear...i.e. the engine starts, column shifter moves just fine, will shift into Neutral but not Reverse or Drive...meaning, the shifter moves to R and N and D but the truck stays in Neutral the whole time, won't even attempt to engage R or D! Ugh!
I've got the extended warranty thru Mopar, bought this truck new in Nov 2011, and it's at the dealership now getting looked at...but just curious as to what Moparts members might be able to tell me about this...?
I checked the fluid and it's clean and does not smell bad, and full. I scanned this myself at home (just scanned, did not clear the code) and the code for Low Transmission Pressure came up.
Any ideas? Will the fix be something simple or new transmission? Any guesses?
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red
06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II
06 Chrysler 300C AWD 5.7L Hemi
10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI
10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI
11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red
16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
Re: 2011 Ram 1500 5.7L won't go into gear? [Re: AdventurerSport] #1734325
01/19/15 07:46 PM
01/19/15 07:46 PM
Morningside
Morningside
This is odd...the filter came loose inside the pan!
The tech has replaced the filter, flushed the trans and re-filled with ATF, out test-driving now. I hope that is all that is wrong!
JS
Re: 2011 Ram 1500 5.7L won't go into gear? [Re: AdventurerSport] #1734326
01/19/15 08:20 PM
01/19/15 08:20 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
never heard of that before. bizarre
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: 2011 Ram 1500 5.7L won't go into gear? [Re: VincentVega] #1734327
01/19/15 08:33 PM
01/19/15 08:33 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Sounds like a trans service gone bad.
Re: 2011 Ram 1500 5.7L won't go into gear? [Re: stumpy] #1734328
01/19/15 11:37 PM
01/19/15 11:37 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
If its the 45RFE or 545RFE trans then it can happen as the main filter in the pan (it has 2 filters) pushes up into the valve body and has a seal that pushes in the valve body first then the filter neck pushes into the seal which is a metal outer coated housing so the seal ring stays pressed in the valve body. But may times I have seen either a tech did not install the seal right in a trans service or the factory did not get it in right and the filter neck does not seat right and just sucks in air since the filter neck is above the fluid level. The filter can fall out or its just not sealed because the seal is not in right and it does not suck any fluid into the pump because its just pulling in air from the loss of the sealing at the filter neck to the valve body and it will of course set that code since the pressure switch will see no trans fluid pressure. Ron
Re: 2011 Ram 1500 5.7L won't go into gear? [Re: 383man] #1734329
01/20/15 02:09 AM
01/20/15 02:09 AM
Morningside
Morningside
Yup, that's what happened! All is well now, new fluid, filter and she goes like new! 545RFE behind a 5.7 in a 2011 Ram 1500.
What is the recommended service interval for this transmission? And, does this one still use ATF+4 or something else?
Thanks!
JS
Re: 2011 Ram 1500 5.7L won't go into gear? [Re: AdventurerSport] #1734330
01/21/15 04:50 AM
01/21/15 04:50 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thanks!
JS
Glad to hear all is good. Yes ATF+4 is what that should use. Ron
Re: 2011 Ram 1500 5.7L won't go into gear? [Re: 383man] #1734331
01/21/15 06:58 PM
01/21/15 06:58 PM
Morningside
Morningside
Thanks! Runs great now, no issues after this repair (under warranty, too boot!)
JS
Re: 2011 Ram 1500 5.7L won't go into gear? [Re: AdventurerSport] #1734332
01/22/15 10:01 PM
01/22/15 10:01 PM
Temecula, Ca.
Z
zzyzxpat Offline
zzyzxpat  Offline
Z
Temecula, Ca.
The fix for that is to use a GM 125 filter seal instead of the stock one. It will seal the filter tighter and help to keep the neck from coming loose. We do it on all builds.
Pat
" The last official act of any goverment, is to loot the treasury" George Washington
