Rubber body mount bushings #1733827
01/19/15 03:52 AM
01/19/15 03:52 AM
Pyeongtaek, South Korea
69HemiGTX Offline OP
OK, I need to know if there are any sources for rubber body mount bushings - NOT POLY. I don't want any poly bushings anywhere. I know they have to be available somewhere. These are for a 78 crew cab, but Ramcharger bushings work, too.
OIF V and OEF X veteran and proud of it!
Re: Rubber body mount bushings [Re: 69HemiGTX] #1733828
01/21/15 12:26 PM
01/21/15 12:26 PM
Germany, Berlin
muskote Offline
muskote  Offline
Germany, Berlin
Good question.
Iīve been searching for my 75 Ramcharger too, and wasnīt able to locate any rubber sets so far. Only the Polyurethan stuff is available from Energy Suspension and one more supplier....
I bought the set from Energy Suspension but havenīt mounted it yet.
I came across two websites that offer rubber stuff, but not specifically for trucks.
At least they have listed the dimensions in their descriptions, so it would be a challenge to get the needed stuff together....
Have a look:
http://stores.restorationspecialties.com/body-mounts-solid-rubber/
http://www.steelerubber.com/body-mount-pad-fittings
