Re: Are engine mount bolts really special???
[Re: 7812845]
#1733579
01/18/15 11:39 PM
01/18/15 11:39 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
I need to locate some engine mounting bolts for my car so I thought I might just get some new ones while I'm at it. They are selling for $25 new. Am I missing something?? That sure seems like a bunch of money for them. What's so special to make them this expensive??
since i'm not a numbers guy it doesn't matter to me. I just go to the hardware store and buy hardened (grade 8) ones. then I discovered a local hardware store that has an unbelievable selection of stainless! so now when I take something apart, I replace with stainless hardware!
[Re: 7812845]
#1733582
01/19/15 12:28 AM
01/19/15 12:28 AM
Posts: 893 Tustin, CA
pishta
Tustin, CA
Dont even need to be grade 8. 5 is fine and get fine pitch. The expensive ones probably have the M or factory vendor letter in them as off the line. Kinda like rosette rivets....
12 Grand Caravan 06 T&C 02 T&C 96 Breeze 65 Barracuda "S"
[Re: RoadRunner]
#1733589
01/20/15 04:40 PM
01/20/15 04:40 PM
mikemee1331
bethlehem pa
Carefull on the stainless bolts. Most stainless bolts are not equivalent to grade 5. I had a chart somewehre that showed the strength of stainless versus the various grades. I was surprised. If its not a high load bolt, then you probably OK. But I would stick with grade 8s or minimally grade 5s for motor mounts.
WOW!! I didn't know that and of course had to research it. it seems they are equivalent to a grade 2 bolt! Luckily (I hope ) the mission has been limited to bolt on stuff like thermostat housing, carb nuts and that type of thing. i know i did my motor mount brackets in grade 8. well, mission aborted! thanks for the heads up!
