B Body Hood Sealant/Adhesive #173339
12/23/08 12:42 PM
12/23/08 12:42 PM
Arizona
69rrconvert Offline OP
Arizona
I have a hood that has what looks like spot welds on the underside between the top piece and the cross ribs. Some of these have broken loose and let the top skin move. I scrapped it with a knife and it looks like it is some kind of hardening sealant. What is this sealant or adhesive that is used on a B body hood between the top sheet metal and the reinforcement ribs on the underside of the hood? Also, where can it be purchased? Thanks
Re: B Body Hood Sealant/Adhesive [Re: 69rrconvert] #173340
12/23/08 06:17 PM
12/23/08 06:17 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The inner and outer sections were only spot welded at the perimeter, not across the surface. Those "blobs" are an adhesive/sealant that was probably meant to stay pliable for the life expectancy of the car. Unfortunately after 40 years or so its hardened and now come loose.
Since this adhesive/sealant is applied PRIOR to the halves being put together, the tough part is going to be duplicating the original squish pattern.
As far as what to use, I don't know if there is an exact product on the market since technology has changed these materials significantly but if it were me I'd use a paintable body sealer. You'll have to work with clean, bare metal as was originally done or it will just pull off again.
Re: B Body Hood Sealant/Adhesive [Re: Stanton] #173341
12/23/08 06:31 PM
12/23/08 06:31 PM
Arizona
Arizona
Thanks for the reply. You are correct in saying the sealant has hardened over the years. When I scrapped it with a knife, it kind of looks like bondo
Re: B Body Hood Sealant/Adhesive [Re: 69rrconvert] #173342
12/23/08 06:43 PM
12/23/08 06:43 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Re: B Body Hood Sealant/Adhesive [Re: 1_WILD_RT] #173343
12/23/08 07:06 PM
12/23/08 07:06 PM
Arizona
Arizona
Thanks........should have known that Eastwood would have something for this
Re: B Body Hood Sealant/Adhesive [Re: 69rrconvert] #173344
12/23/08 10:49 PM
12/23/08 10:49 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
u do know that requires a special chalking gun?
Re: B Body Hood Sealant/Adhesive [Re: 05dakota] #173345
12/23/08 10:57 PM
12/23/08 10:57 PM
Williamsport, PA
Kingy Offline
Royal Pain
Kingy  Offline
Royal Pain
Williamsport, PA
Evercoat Maxim panel bonding adhesive. Not cheap but it fits in a standard size caulking gun and you can reseal the container.
Re: B Body Hood Sealant/Adhesive [Re: Kingy] #173346
12/24/08 11:31 AM
12/24/08 11:31 AM
Arizona
Arizona
Thanks for the replys.........I appreciate it
