What hiway RPM with what gears with 518?
#1732959
01/18/15 05:00 PM
01/18/15 05:00 PM
Posts: 12,162 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I am considering swapping the 727 in the Cuda for a 518. I have 3.91s now and was just wondering what RPMs the different rear ratios give at hiway speeds. Say 70ish MPH.
I know there are other variables, but I was just looking for some ball parks from those that are already running the 518s.
With the tall tires and loose converter, the engine spins about 3,000 RPM at about 55MPH now.
Thanks!
Master, again and still
Re: What hiway RPM with what gears with 518?
[Re: DaveRS23]
#1732960
01/18/15 05:06 PM
01/18/15 05:06 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The OD ratio is .69, so multiply whatever RPM you are getting now by .69 and that will be your new RPM, give or take a few for slippage. So 3000@55 would be 2070@55.
[Re: Supercuda]
#1732961
01/18/15 05:09 PM
01/18/15 05:09 PM
Posts: 1,106 Northeast
VincentVega
Northeast
you'll also get a significant reduction in RPM if you're working the lockup converter into the equation
I've always liked the idea of a loose converter, w/ lockup
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
[Re: VincentVega]
#1732962
01/18/15 05:12 PM
01/18/15 05:12 PM
Supercuda
About to go away
About to go away
up yours
Yeah, I assume his current converter is not a lockup so there is probably a couple hundred rpm gain there on top of the OD ratio.
[Re: DaveRS23]
#1732964
01/18/15 07:49 PM
01/18/15 07:49 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I was considering the lock-up version thinking along the same lines as you. But PTC said that the lock-up would limit the converter choice, so I picked up a non lock up 518 core tranny. I have a 4,000 stall in the car now, but I doubt that I will want that loose a converter with this next build especially given the higher OD tranny ratio.
The overall combo I am thinking about is something like a converter flash between maybe 3,000 and 3,500 RPM and a rear gear that will let the engine stay 3,000 RPM or less in OD at about 70 MPH. Nothing set in stone here, just beginning targets.
Of course, I have to wait to install the 518 until the bells are available again. Anyone have any news on that front?
[Re: nomore65BelvJim]
#1732966
01/18/15 08:02 PM
01/18/15 08:02 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I am open to a recommendation.
#1732968
01/18/15 09:26 PM
01/18/15 09:26 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Thanks for the heads up on the JW. I will check with them tomorrow. Everyone has said for quite some time now that they were on B/O. Obviously, I didn't check myself.
I drove the car this afternoon and it tached about 3,800RPM @ 70 MPH. So multiplying by .69, that gets me to about 2,600 with the OD. That will work.
Thanks for all the help.
[Re: DaveRS23]
#1732971
01/18/15 10:14 PM
01/18/15 10:14 PM
Posts: 16,844 Phoenix - surface of the sun
nomore65BelvJim
No problem. I never bothered to check either, I dont need another one. Please post back with the availability, yea or nay. The only real exterior difference 727 vs. 518 is in the tail housing, where the OD unit is. Lots of good info on the swap, Id'ing the trans, etc. in the tech archives here on moparts.
