so I had to replace my leaf springs again. I bought a new set from espo/springs and things about 6 years ago.
They were for an early b. BUT, I got hangers from firm feel and got the modded hangers for ebody leaf springs.
This caused the leafs to flattened the leafs after about 2 years. Which I didn't realize at the time what had happened.
I finally got a chance to pick up a new set. Went with an ebay seller for mckveigh's springs.
So they were for an ebody with 2 inch lift.
look at how much thicker they are compared to the espo springs.
Top one is my old espo spring, bottom 2 are the new springs.
middle of the packs.
overall
the angle is bad, but you can see the old set is longer than the new.
now the hangers are basically vertical with the car on the ground, which I guess is ok.
I don't remember if they should be pointed forward or back, but I think back?
