Re: T56 and T56 Magnum oil pump
[Re: 72Swinger]
#1732337
01/17/15 09:35 PM
01/17/15 09:35 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Why not for very little extra effort include at least the simplest cooler?
[Re: RylisPro]
#1732340
01/18/15 12:44 AM
01/18/15 12:44 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
My only concern is just more S$$$ under my car lol. I will already have around 10-12 Relays worth of electronic gadgetry whats more plumbing right?
Mopar to the bone!!!
[Re: 72Swinger]
#1732341
01/18/15 11:49 AM
01/18/15 11:49 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I can do back to back runs down the track, and my trans temp will barely move. but, If I'm cruising down the highway at 75mph in 6th gear, my temps will increase rapidly. I've seen 220 degrees on mine. makes me nervous, but everyone I've talked to says that 250 is the danger point, and not to sweat seeing 220.
I know there's a lot of plastic in the trans though, and plastic does not like heat. (needle bearing cages, thrust washers, etc. made from plastic)
**Photobucket sucks**
[Re: RylisPro]
#1732342
01/18/15 11:56 AM
01/18/15 11:56 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
If I added a pump to my T56, I would also add a cooler. No harm in over cooling a transmission.]
I would expect to see peak efficiencies at higher temps. A thermostat inline may not be a bad idea to ensure the oil stays warm enough on cold days to properly lube the trans.
