Re: Street Demon, Rich Idle.
[Re: midnite360]
#1732150
01/17/15 02:45 PM
01/17/15 02:45 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
What is your initial timing?
Idle mixture adjustment is done with the metering screws. How many do you have (2 or 4)?
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: midnite360]
#1732151
01/17/15 02:53 PM
01/17/15 02:53 PM
RapidRobert
I'd elim float setting and psi. yes you need enough initial to have the throttle closed enough to not be in the mains/transition? circuits at idle speed. how many turns CCW (out) till the throttle JUST stops moving
[Re: midnite360]
#1732153
01/17/15 11:38 PM
01/17/15 11:38 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Yup. You're on the right path. Getting the engine to fire is OK, but next you have to set it for best combustion. With a somewhat radical cam, it will need a richer than stock mixture and a bit more initial idle timing (than stock). Use the charts on this link with your cam's duration to get a ballpark for the initial timing. http://www.demoncarbs.com/Tech/DemonSelectionGuide.aspThe Street Demon is new but the principles of its operation appear to simply be a rework of the Thermoquads and its predecesors. You should be able to get the idle and off idle by adjusting the throttle position (aka idle speed screw) and the idle mix screws - once the timing and fuel level are where they ought to be. If you find it drops rpm a bunch when you put it in gear, then its too lean (and probably a bit too much timing) to make power at idle. If you're curious about Air/Fuel ratio vs. load this post will help. http://racingfuelsystems.myfunforum.org/...d_about421.htmlAlso some folks on that forum that can help if you do need to do some tuning with that carb. Q-jets, t-quads, and zeniths are not feared or shunned there.
[Re: midnite360]
#1732155
01/18/15 12:39 AM
01/18/15 12:39 AM
Posts: 12,074 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
What's the overlap on that cam? If you have a lumpy idle, there may be enough pulses in the intake to keep the idle stinky. Do you have an O2?
Master, again and still
[Re: midnite360]
#1732157
01/19/15 12:51 AM
01/19/15 12:51 AM
Posts: 893 Tustin, CA
pishta
Tustin, CA
Interesting...."Demon Carburetion® & BG Fuel Systems are registered trademarks of Holley Performance Products, Inc"
Love the new TQ Demons. we used to manipulate the TQ tree height screw for global A/F changes. Idle is all mixture screws..
12 Grand Caravan 06 T&C 02 T&C 96 Breeze 65 Barracuda "S"
