1968 a- body A/C questions
#1732102
01/17/15 01:40 PM
01/17/15 01:40 PM
Posts: 1,383 Az
69hemibeep
Az
My 68 valiant project is an A/C car and I would like to put the unit back together using an after market compressor. My problem is that I have two dead vacuum motors that control air doors in the box. Is there replacements anywhere or should I just go with a vintage air unit. Oh I'm adding a console will that interfere with the factory vents?
1969 Hemi Roadrunner 2nd owner
Re: 1968 a- body A/C questions
[Re: GTSDart340]
#1732104
01/18/15 11:15 AM
01/18/15 11:15 AM
Posts: 1,383 Az
69hemibeep
Az
Thanks about the console, I'm bumping it back up once for the vacuum question.
[Re: 69hemibeep]
#1732105
01/19/15 02:51 AM
01/19/15 02:51 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
This is a good topic for discussion. I'll bet a lot of people have had problems with the vacuum motors, but I have never seen much discussion here. Maybe it is only the folks in AZ and Houston that care?
Try the Google Custom Search at the top of the page.
[Re: 69hemibeep]
#1732106
01/19/15 05:12 PM
01/19/15 05:12 PM
Posts: 25,794 Rio Linda, CA
John_Kunkel
Rio Linda, CA
As you can see, the vacuum pot halves are joined by a rolled crimp; I have tried with little success to un-crimp them. I have used a belt sander to sand away the crimp on the edge to separate the two halves and expose the innards.
The rubber diaphragm will usually be found brittle and cracked with a pushrod riveted to the center of the rubber. Grind away the rivet to remove the pushrod.
A new diaphragm can be made from thin sheet rubber (I prefer sheet silicone) and the pushrod reattached with a pop rivet. I then place the two halves of the pot together and clamp them securely and then use liberal amounts of epoxy on the previously crimped rim to hold them together.
I have successfully "saved" a couple of pots that were impossible to find in usable condition.
