Sound Deadening Material - Lesson Value or Harm Metal? #1731921
01/17/15 11:44 AM
01/17/15 11:44 AM
Georgia
Steve Bryant Offline OP
Georgia
This post is only semi-technical I guess. I as I start to plan the interior teardown of my '70 Cuda and I find myself on the fence with this matting I bought.
1) From an investment or even show standpoint, is having sound deadening material under the carpet a bad thing? I was intending to only use it where the carpet jute is lacking and in key spots on the dash.
2) Do the deadening mats create any additional problems to the metal? Do they leave little tar patches or are they impossible to remove?
I am really on the fence here. I like the engine/road noise but I don't like the squeaks so I was going to use it sparingly for some dash contact points (plastic on metal, etc). I have seen people line their doors, firewall, floor, etc but I think I value "original" more than "quiet".
Re: Sound Deadening Material - Lesson Value or Harm Metal? [Re: Steve Bryant] #1731922
01/17/15 01:04 PM
01/17/15 01:04 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
just my here.
if you are building a 100 point show car don't use it.
if you building a really nice driver car I highly recommend using it.
there are a LOT of different sound deadeners.
the type I have used and seen others use is a tar based self sticking adhesive pads, some are foil backed for heat resistance. this type works great, it's almost impossible to remove. most sound deadening materials will be difficult to remove.
in my opinion is it won't make the car worth less. it won't make your car worth more but it will make you car much easier to sell because the car will be a much nicer car to drive.
perception is 90% of reality
Re: Sound Deadening Material - Lesson Value or Harm Metal? [Re: Mr T2U] #1731923
01/17/15 01:19 PM
01/17/15 01:19 PM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
I agree with Mr T2U
Re: Sound Deadening Material - Lesson Value or Harm Metal? [Re: Steve Bryant] #1731924
01/17/15 03:02 PM
01/17/15 03:02 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
If you don't like the squeaks, creaks, and rattles, then install subframe connectors. They will do more to eliminate the noises then sound deadener will do to reduce it.
Re: Sound Deadening Material - Lesson Value or Harm Metal? [Re: TC@HP2] #1731925
01/17/15 06:49 PM
01/17/15 06:49 PM
Georgia
Georgia
Thanks all. The squeaks and pops I have are in the current dash. Once I strip and coat the dash frame, I may use some small strips of deadened to get the dash parts to align better and to prevent dash noises.
The floor is pretty quiet so I think I will go ahead and use some matting where there is no jute like along the hump, under the rear seat and a little higher up on the firewall.
I am using the foil-backed GT Pro matting. I was concerned about the "impossible to remove" factor so I think I will just use it where it would be best served instead of everywhere.
I really appreciate you guys and your time and opinions.
Re: Sound Deadening Material - Lesson Value or Harm Metal? [Re: TC@HP2] #1731926
01/18/15 03:40 AM
01/18/15 03:40 AM
Queens, N. Y.
FASTBACK340 Offline
FASTBACK340  Offline
Queens, N. Y.
While I agree 100% on the frame connectors, I dis agree on the application here. They will do nothing as a heat barrier, which was an issue in my car before I restored it. The matting not only quieted the interior, but made it a bit more comfortable too.
`68 Barracuda 340-S
Re: Sound Deadening Material - Lesson Value or Harm Metal? [Re: FASTBACK340] #1731927
01/18/15 11:38 AM
01/18/15 11:38 AM
Georgia
Georgia
Thanks for the note. As far as heat is concerned, I assume that the heat is coming in from the pipes below, the hump above the transmission and the firewall up front.
I assume it is the aluminum coating that will help reduce that especially where the jute is absent.
Re: Sound Deadening Material - Lesson Value or Harm Metal? [Re: Steve Bryant] #1731928
01/18/15 08:10 PM
01/18/15 08:10 PM
Queens, N. Y.
FASTBACK340 Offline
FASTBACK340  Offline
Queens, N. Y.
Yes, I have headers and an X pipe, plus the shifter opening in the floor. The matting helped quiet it down, and was a very good heat barrier. I bought a roll of FatMat on e-Bay for about $100 or so shipped. I covered my entire firewall, floor pan all the way back to the shock mounts (I have a fastback), the rear wheel housings, and the roof. I also added strips inside my doors. Car used to be an oven, now it's actually nice with the fresh-air vents open.
`68 Barracuda 340-S
Re: Sound Deadening Material - Lesson Value or Harm Metal? [Re: FASTBACK340] #1731929
01/19/15 12:24 PM
01/19/15 12:24 PM
Georgia
Georgia
Very nice! Thanks for the photos.
