Positive vs. negative piston deck height #173181
12/23/08 12:07 AM
12/23/08 12:07 AM
Central Coast
P
Plumcrazyracing Offline OP
P
Central Coast
Just got a call from my machine shop and learned that i needed take more off the block than anticipated. Pistons are now going to be about .008 out of the hole. I figure i will run a cometic compressed at about .051 to give a quench of .043. Any opinions as to having a positive deck hieght like this?
Re: Positive vs. negative piston deck height [Re: Plumcrazyracing] #173182
12/23/08 12:45 AM
12/23/08 12:45 AM
Canada
CrAzYMoPaRGuY Offline
Canada
Depends on the heads etc, but many 383s were positive deck height stock I believe...?
CrAzYMoPaRGuY
Re: Positive vs. negative piston deck height [Re: Plumcrazyracing] #173183
12/23/08 01:40 AM
12/23/08 01:40 AM
all domes are usually above the top of the deck, the 1970 440 6 paks where .005 above and the early HP 340 (Pre 1972) called for a positive deck hieght also. The last legal 340 stocker I built had the pistons around .030 above, if I'm remembering the blueprint spec on the piston deck hieghts correctly
Re: Positive vs. negative piston deck height [Re: Plumcrazyracing] #173184
12/23/08 01:49 AM
12/23/08 01:49 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
At that positive deck height .008 I wouldnt be concerned about a thing/nothing mike
Re: Positive vs. negative piston deck height [Re: Sport440] #173185
12/23/08 01:56 AM
12/23/08 01:56 AM
Central Coast
P
P
Central Coast
Thank you. Makes me feel better.
Re: Positive vs. negative piston deck height [Re: Plumcrazyracing] #173186
12/23/08 02:20 AM
12/23/08 02:20 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
That deck height sounds very reasonable to me. 008 above is nothing to worry about.
Re: Positive vs. negative piston deck height [Re: Plumcrazyracing] #173187
12/23/08 02:55 AM
12/23/08 02:55 AM
Owego, NY
JBurch Offline
JBurch  Offline
Owego, NY
I'm currently running my 360 with the pistons .008 out of the hole, .039 gasket, no worries.
Re: Positive vs. negative piston deck height [Re: JBurch] #173188
12/23/08 07:16 PM
12/23/08 07:16 PM
Alberta, Can
JUST_N_TIME Offline
JUST_N_TIME  Offline
Alberta, Can
would that be with open chamber or closed chamber heads?
Re: Positive vs. negative piston deck height [Re: JUST_N_TIME] #173189
12/23/08 09:20 PM
12/23/08 09:20 PM
houston texas
gremlinsteve Offline
houston texas
heck..late model 6.1 3g hemis are 15 out of the hole new. the 5.7 is less...like 5
steve
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: Positive vs. negative piston deck height [Re: JUST_N_TIME] #173190
12/23/08 09:55 PM
12/23/08 09:55 PM
Central Coast
P
P
Central Coast
Closed chamber Indy's. .620 lift solid roller on my 493 stroked 440
Re: Positive vs. negative piston deck height [Re: Plumcrazyracing] #173191
12/23/08 10:07 PM
12/23/08 10:07 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
In that case that with that .008 positive piston deck height will cause you a whole heap of trouble.
Plum I , think that open vs closed question was directed a jburch. Plum you will be fine with a closed chamber, jburchs head if its closed is on the tight side. mike
Re: Positive vs. negative piston deck height [Re: Sport440] #173192
12/23/08 10:18 PM
12/23/08 10:18 PM
Central Coast
P
P
Central Coast
oops, you're right. Thanks for the info.
Re: Positive vs. negative piston deck height [Re: Plumcrazyracing] #173193
12/23/08 11:20 PM
12/23/08 11:20 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
A safe way to make sure it'll have proper head clearance is to bolt the head on without the gasket and make sure the engine will turn over by hand. Then once you add the head gasket you'll have at least the .039. The pistons on my 451 stick up a little bit. I went with open chambered Edelbrocks and all worked out perfect.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: Positive vs. negative piston deck height [Re: 69dart] #173194
12/24/08 12:43 AM
12/24/08 12:43 AM
Glendale Az
Darryls-Demon Offline
Glendale Az
I have a .030 over 440 with Indy SRs. My pistons are 5 out of the hole using a Felpro .039 head gasket. But I will only run it to 6500. The engine builder did spin it to 6900 on the dyno on one of the break in pulls.
Re: Positive vs. negative piston deck height [Re: JUST_N_TIME] #173195
12/24/08 02:47 AM
12/24/08 02:47 AM
Owego, NY
JBurch Offline
JBurch  Offline
Owego, NY
It's a closed chamber head
Re: Positive vs. negative piston deck height [Re: JBurch] #173196
12/24/08 04:24 PM
12/24/08 04:24 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
You also need to check your piston to valve clearance. -Bob
Re: Positive vs. negative piston deck height [Re: BobR] #173197
12/25/08 10:27 AM
12/25/08 10:27 AM
Toronto Ontario, Can
Glen440 Offline
Glen440  Offline
My 511 was originally .023 above deck. My 400 block was not close to square. Every piston was a different height till I had the machine shop square it. I fixed it with a .062 head gasket.
My custom pistons that are in it now have .025 less pin height to put them -.002.
87 dakota 6.1 hemi
Re: Positive vs. negative piston deck height [Re: Darryls-Demon] #173198
12/25/08 10:50 AM
12/25/08 10:50 AM
yarnell,az
mopacltd Offline
mopacltd  Offline
yarnell,az
I have read that a .055 piston to head clearance is the minimum you should have. Is this not true?
Re: Positive vs. negative piston deck height [Re: BobR] #173199
12/25/08 01:31 PM
12/25/08 01:31 PM
Owego, NY
JBurch Offline
JBurch  Offline
Owego, NY
I checked piston to valve clearance, as well as piston to head clearance before lighting the fires. P to V ( as foggy memory allowes me to remember ) was .070+, .090+ intake and exhaust, P to H was .031. The pistons are KB 107's, not lots of clearance, they don't rock much. I'm not worried.
Re: Positive vs. negative piston deck height [Re: mopacltd] #173200
12/25/08 01:34 PM
12/25/08 01:34 PM
Owego, NY
JBurch Offline
JBurch  Offline
Owego, NY
As I remember, .030 to .060 is the range of ideal quench. More you lose benifit, less you go clank!
