Re: Positive vs. negative piston deck height
[Re: Plumcrazyracing]
#173183
12/23/08 01:40 AM
12/23/08 01:40 AM
Posts: 43,115 Bend,OR USA
Cab_Burge
all domes are usually above the top of the deck, the 1970 440 6 paks where .005 above and the early HP 340 (Pre 1972) called for a positive deck hieght also. The last legal 340 stocker I built had the pistons around .030 above, if I'm remembering the blueprint spec on the piston deck hieghts correctly
#173184
12/23/08 01:49 AM
12/23/08 01:49 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Just got a call from my machine shop and learned that i needed take more off the block than anticipated. Pistons are now going to be about .008 out of the hole. I figure i will run a cometic compressed at about .051 to give a quench of .043. Any opinions as to having a positive deck hieght like this?
At that positive deck height .008 I wouldnt be concerned about a thing/nothing mike
[Re: JUST_N_TIME]
#173189
12/23/08 09:20 PM
12/23/08 09:20 PM
Posts: 1,828 houston texas
gremlinsteve
houston texas
heck..late model 6.1 3g hemis are 15 out of the hole new. the 5.7 is less...like 5
steve
if You Like Gremlinsteve. Gremlinsteve Likes You.
[Re: JUST_N_TIME]
#173190
12/23/08 09:55 PM
12/23/08 09:55 PM
Posts: 184 Central Coast
Plumcrazyracing
Central Coast
Closed chamber Indy's. .620 lift solid roller on my 493 stroked 440
#173191
12/23/08 10:07 PM
12/23/08 10:07 PM
Sport440
Canton, Ohio
In that case that with that .008 positive piston deck height will cause you a whole heap of trouble.
Plum I , think that open vs closed question was directed a jburch. Plum you will be fine with a closed chamber, jburchs head if its closed is on the tight side. mike
[Re: BobR]
#173197
12/25/08 10:27 AM
12/25/08 10:27 AM
Posts: 1,397 Toronto Ontario, Can
Glen440
My 511 was originally .023 above deck. My 400 block was not close to square. Every piston was a different height till I had the machine shop square it. I fixed it with a .062 head gasket.
My custom pistons that are in it now have .025 less pin height to put them -.002.
87 dakota 6.1 hemi
