Page 1 of 5 1 2 3 4 5
The great oil pan gasket question for big block mopar #1731102
01/16/15 02:42 AM
01/16/15 02:42 AM
Utah, USA
1964superstock Offline OP
Utah, USA
From first hand experience, what is the best way to prevent new oil pan gaskets on a 440 engine from leaking? My 440 is now a 505 ci stroker, using a Chenoweth main girdle, windage tray, and Milodon oil pan. It runs great, but the oil pan is leaking bad at the rear. The rear main seal is dry. I want to fix the oil pan leak right and be done with it.
I am considering using the Fel-Pro 1834 oil pan gaskets, or the Superperformance #2585 oil pan gaskets. Is one better than the other?
When using a two Fel-Pro 1834 oil pan gaskets with a windage tray, would it be most likely leak free using Permatex® Ultra Rubber Gasket Sealant & Dressing Part Number 85409, or……….by using Permatex® Ultra Grey Rigid High-Torque RTV Silicone Gasket Maker ? OR....don't use any sealant or silicone? Would this be the same for Superformance oil pan gasket #2585 ?
Fel-Pro 1834 oil pan gasket, 2 piece steel and rubber:
http://www.fme-cat.com/overlays/part-det...&brandId=FL
http://www.summitracing.com/parts/fel-1834
http://www.manciniracing.com/suoilpangase1.html
Re: The great oil pan gasket question for big block mopar [Re: 1964superstock] #1731103
01/16/15 02:50 AM
01/16/15 02:50 AM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I have always used the Fel-Pro 1834 but I believe the guy that makes Superformance gaskets is a member here on Moparts. The Superformance gasket material is awesome.
Re: The great oil pan gasket question for big block mopar [Re: 1964superstock] #1731104
01/16/15 02:52 AM
01/16/15 02:52 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
que the GM clownt with his rant on different length oil pan bolts ... even though you have a girdle and his rant does not even have any thing to do with this ... in 3 , 2 , 1 ...
Use the superformance gasket and make sure you pan rails are nice and flat ...
Re: The great oil pan gasket question for big block mopar [Re: JohnRR] #1731105
01/16/15 02:55 AM
01/16/15 02:55 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Superformance, if you are going to buy one gasket from them make it the oil pan gasket. Cork oil pan gaskets want to compress to easily and bulge out, paper rips. Superformance stays nice and doesn't compress out of the side of the pan with 15 inch pounds of torque on each bolt. Hands down best gaskets I've seen, wish I had bought a whole kit from him before I got my engine half together.
No RTV. Let the gasket do the work, even with the cork fel pro junk. I smear a little where the timing cover meets the block though. Don't go crazy.
Re: The great oil pan gasket question for big block mopar [Re: GTX MATT] #1731106
01/16/15 03:23 AM
01/16/15 03:23 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Use Perma-Tex Aviation Gasket Maker, let it set up, and DONT overtighten the bolts.
10 years with a 383, a 451, and two different pans... I've never had a pan gasket leak.
Re: The great oil pan gasket question for big block mopar [Re: GTX MATT] #1731107
01/16/15 03:25 AM
01/16/15 03:25 AM
Sherwood park, Alberta.
go green Offline
go green  Offline
Having a good oil pan with a 1/2 pan rail helps , I put a small amount of silicone in the rear main center bolt holes and a dab at the timing chain seam . (1834 gasket with the steel core ) pan comes off 10 or more times a year same gasket .
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: The great oil pan gasket question for big block mopar [Re: go green] #1731108
01/16/15 09:23 AM
01/16/15 09:23 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The Superformance gaskets work well. I also add a little RTV at the rear cap area/timing chain cover. If the pan itself is suspect of not being completely flat a 1/8" bead of RTV between the pan and gasket will cure it. Mine don't leak a drop.
Doug
Re: The great oil pan gasket question for big block mopar [Re: dvw] #1731109
01/16/15 11:35 AM
01/16/15 11:35 AM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
I agree that the Superperformance gasket works very well on a stamped steel pan or a fabricated pan with a solid rail. Another option for the fabricated pan is the windage tray from Jegs with the built in gasket. It is very similar to the reusable transmission pan gasket that Mopar sells.
http://www.jegs.com/i/JEGS+Performance+Products/555/502001/10002/-1
Re: The great oil pan gasket question for big block mopar [Re: PC-CHARGER] #1731110
01/16/15 12:09 PM
01/16/15 12:09 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Another SuperPerformance vote. Put it on dry with maybe some gasket sinche just to hold it in place on one side when assemled. No leaks whatsoever.
Best there is
Russ
Re: The great oil pan gasket question for big block mopar [Re: max_maniac] #1731111
01/16/15 12:19 PM
01/16/15 12:19 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
After leaks with the Jegs composite windage tray/gasket, I returned it for a refund.
I now see they recommend using it with cast pans with solid gasket
surfaces, unlike the stamped pans.
Joe
Re: The great oil pan gasket question for big block mopar [Re: jlatessa] #1731112
01/16/15 12:42 PM
01/16/15 12:42 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Once you use the Superformance gaskets you'll wonder why you ever settled for the other gaskets out there.
I love leak free engines!
Keith
Re: The great oil pan gasket question for big block mopar [Re: 1964superstock] #1731113
01/16/15 12:44 PM
01/16/15 12:44 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I can assure you will not find a better "Quality" oil pan gasket than what we offer here at Superformance Products.
If you choose to support us here are some installation tips for your application.
1) As we all should know, clean, flat surfaces are a must with any gasket install. Pay particular attention to the gasket rail on your stamped steel pan and correct where needed.
2) When you are ready to install apply a 1/8" "BEAD" of Permatex Ultra Black directly to the oil pan rail perimeter. Also apply at the timing chain cover to block joint and the rear main seal retainer. You should need nothing on the block surface or the windage tray, given it's not bent out of shape.
3) If you wish to retain the gasket to the oil pan rail of the block for ease of installation while on your back under the car with oil dripping on your forehead
Apply a small amount of Contact Adhesive between bolt holes on the block and gasket and allow to tack up before attempting installation.
4) Once everything is in place with a couple bolts started. Install remaining bolts and tighten "just snug" to disperse the Permatex Ultra Black,
5) Wait 24 hours for sealer to cure then tighten all bolts to desired torque.
Here's the issues with using the "others"
F-P 1834, has a steel core and is pretty thick to use doubled up with a windage tray.
F-P 1808, good luck trying to get it flat on the front and back ends after it's been folded in 1/2 and rubber banded to cardboard tubes for who knows how long.
Milodon "Crush Proof", it's anything but and is one of the most economical materials on the market.
Jegs Polymer windage tray with molded in sealing beads has very little sealing contact area, less than any composition gasket.
Thanks for all the positive responses
Where else can you get direct feedback like this
Re: The great oil pan gasket question for big block mopar [Re: jlatessa] #1731114
01/16/15 12:47 PM
01/16/15 12:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Joe
Thats the thing... if you dont have a flat stiff surface
its gonna leak... I use to beat those 440 pans back
flat each time they went back on
Re: The great oil pan gasket question for big block mopar [Re: MR_P_BODY] #1731115
01/16/15 01:48 PM
01/16/15 01:48 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I pretty much the same set up as the op, I had a rear oil leak and thought at first it was the rear seal, it was dry also, so I looked at the gasket and pan rail, both were good, then I noticed 2 marks on the inside of the pan where the rear main bearing girdle retaining studs were hitting the pan. Smacked the two marks with a ball peen hammer a few times and replaced the pan using the same gasket [ blue Moroso from AutoZone ] No leaks. Just my experience. you might want to look at your pan inside.
Re: The great oil pan gasket question for big block mopar [Re: rowin4] #1731116
01/16/15 03:40 PM
01/16/15 03:40 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
So will anyone be selling Superformance gaskets at the Detroit swap meet next Sunday ??
Re: The great oil pan gasket question for big block mopar [Re: rowin4] #1731117
01/16/15 04:23 PM
01/16/15 04:23 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I trimmed the studs down on the couple engines I did with studs .
Re: The great oil pan gasket question for big block mopar [Re: rowin4] #1731118
01/16/15 10:06 PM
01/16/15 10:06 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
What he said
Re: The great oil pan gasket question for big block mopar [Re: 1964superstock] #1731119
01/17/15 12:55 AM
01/17/15 12:55 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
As many have already said..use the Superformance gaskets.My 440 is as dry as a bone.
Nautilus Racing-
Re: The great oil pan gasket question for big block mopar [Re: 1964superstock] #2033493
03/17/16 11:37 PM
03/17/16 11:37 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
When ordering #2585 is that for a pair or one gasket ?
Also do they sell a rear main seal ?
And some say to put #2585 on dry , while road hazard says put a bead of silicone on the oil pan rail ?
Bought a new reproduction stamped 402 oil pan and windage tray , want to do it right while motor sits in car
Thanx Scott
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: The great oil pan gasket question for big block mopar [Re: 1964superstock] #2033570
03/18/16 02:02 AM
03/18/16 02:02 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Listen to Road hazmat!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
