The great oil pan gasket question for big block mopar
#1731102
01/16/15 02:42 AM
01/16/15 02:42 AM
Posts: 506 Utah, USA
1964superstock
Utah, USA
From first hand experience, what is the best way to prevent new oil pan gaskets on a 440 engine from leaking? My 440 is now a 505 ci stroker, using a Chenoweth main girdle, windage tray, and Milodon oil pan. It runs great, but the oil pan is leaking bad at the rear. The rear main seal is dry. I want to fix the oil pan leak right and be done with it. I am considering using the Fel-Pro 1834 oil pan gaskets, or the Superperformance #2585 oil pan gaskets. Is one better than the other? When using a two Fel-Pro 1834 oil pan gaskets with a windage tray, would it be most likely leak free using Permatex® Ultra Rubber Gasket Sealant & Dressing Part Number 85409, or……….by using Permatex® Ultra Grey Rigid High-Torque RTV Silicone Gasket Maker ? OR....don't use any sealant or silicone? Would this be the same for Superformance oil pan gasket #2585 ? Fel-Pro 1834 oil pan gasket, 2 piece steel and rubber: http://www.fme-cat.com/overlays/part-det...&brandId=FLhttp://www.summitracing.com/parts/fel-1834Superformance oil pan gasket #2585 http://www.manciniracing.com/suoilpangase1.html
Re: The great oil pan gasket question for big block mopar
[Re: JohnRR]
#1731105
01/16/15 02:55 AM
01/16/15 02:55 AM
Posts: 5,163 CT
GTX MATT
CT
Superformance, if you are going to buy one gasket from them make it the oil pan gasket. Cork oil pan gaskets want to compress to easily and bulge out, paper rips. Superformance stays nice and doesn't compress out of the side of the pan with 15 inch pounds of torque on each bolt. Hands down best gaskets I've seen, wish I had bought a whole kit from him before I got my engine half together. No RTV. Let the gasket do the work, even with the cork fel pro junk. I smear a little where the timing cover meets the block though. Don't go crazy.
[Re: GTX MATT]
#1731106
01/16/15 03:23 AM
01/16/15 03:23 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Use Perma-Tex Aviation Gasket Maker, let it set up, and DONT overtighten the bolts.
10 years with a 383, a 451, and two different pans... I've never had a pan gasket leak.
[Re: PC-CHARGER]
#1731110
01/16/15 12:09 PM
01/16/15 12:09 PM
Posts: 6,354 Aurora, Oh.
max_maniac
Aurora, Oh.
Another SuperPerformance vote. Put it on dry with maybe some gasket sinche just to hold it in place on one side when assemled. No leaks whatsoever. Best there is Russ
[Re: 1964superstock]
#1731113
01/16/15 12:44 PM
01/16/15 12:44 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
I can assure you will not find a better "Quality" oil pan gasket than what we offer here at Superformance Products. If you choose to support us here are some installation tips for your application. 1) As we all should know, clean, flat surfaces are a must with any gasket install. Pay particular attention to the gasket rail on your stamped steel pan and correct where needed. 2) When you are ready to install apply a 1/8" "BEAD" of Permatex Ultra Black directly to the oil pan rail perimeter. Also apply at the timing chain cover to block joint and the rear main seal retainer. You should need nothing on the block surface or the windage tray, given it's not bent out of shape. 3) If you wish to retain the gasket to the oil pan rail of the block for ease of installation while on your back under the car with oil dripping on your forehead Apply a small amount of Contact Adhesive between bolt holes on the block and gasket and allow to tack up before attempting installation. 4) Once everything is in place with a couple bolts started. Install remaining bolts and tighten "just snug" to disperse the Permatex Ultra Black, 5) Wait 24 hours for sealer to cure then tighten all bolts to desired torque. Here's the issues with using the "others" F-P 1834, has a steel core and is pretty thick to use doubled up with a windage tray. F-P 1808, good luck trying to get it flat on the front and back ends after it's been folded in 1/2 and rubber banded to cardboard tubes for who knows how long. Milodon "Crush Proof", it's anything but and is one of the most economical materials on the market. Jegs Polymer windage tray with molded in sealing beads has very little sealing contact area, less than any composition gasket. Thanks for all the positive responses Where else can you get direct feedback like this
[Re: jlatessa]
#1731114
01/16/15 12:47 PM
01/16/15 12:47 PM
Posts: 52,972 Romeo MI
MR_P_BODY
After leaks with the Jegs composite windage tray/gasket, I returned it for a refund. I now see they recommend using it with cast pans with solid gasket surfaces, unlike the stamped pans.
Joe
Thats the thing... if you dont have a flat stiff surface its gonna leak... I use to beat those 440 pans back flat each time they went back on
[Re: MR_P_BODY]
#1731115
01/16/15 01:48 PM
01/16/15 01:48 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I pretty much the same set up as the op, I had a rear oil leak and thought at first it was the rear seal, it was dry also, so I looked at the gasket and pan rail, both were good, then I noticed 2 marks on the inside of the pan where the rear main bearing girdle retaining studs were hitting the pan. Smacked the two marks with a ball peen hammer a few times and replaced the pan using the same gasket [ blue Moroso from AutoZone ] No leaks. Just my experience. you might want to look at your pan inside.
[Re: rowin4]
#1731117
01/16/15 04:23 PM
01/16/15 04:23 PM
Posts: 75,060 U.S.S.A.
JohnRR
U.S.S.A.
I trimmed the studs down on the couple engines I did with studs .
#2033493
03/17/16 11:37 PM
03/17/16 11:37 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
When ordering #2585 is that for a pair or one gasket ?
Also do they sell a rear main seal ?
And some say to put #2585 on dry , while road hazard says put a bead of silicone on the oil pan rail ?
Bought a new reproduction stamped 402 oil pan and windage tray , want to do it right while motor sits in car
Thanx Scott
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
