Speedometer question #173075
12/22/08 09:14 PM
12/22/08 09:14 PM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
My 72 Swinger hasnt been run since 1995. I finally got it running today after messing with it for almost a month.
I have the car up on jackstands and when the car is idleing in neutral the speedo needle wants to jump around.
Is this a speedo cable lube issue or is it an issue of the the speedo head needing lubrication.What else could be causing the needle to jump around like that in neutral? The transmission is a 3 speed manual(Column shift)
Re: Speedometer question [Re: SPWC] #173076
12/22/08 09:47 PM
12/22/08 09:47 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Pull the cable core and clean and lube it. That should fix your problem.
Re: Speedometer question [Re: stumpy] #173077
12/22/08 09:51 PM
12/22/08 09:51 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
The jumping needle is a lube issue.
The fact that the speedo is trying to register at all is because the output shaft (and rear tires) are turning a bit.
Down to just a blue car now.
Re: Speedometer question [Re: 68HemiB] #173078
12/23/08 11:57 AM
12/23/08 11:57 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
yeap... torque converter inertia with tranny makes to spin a little bit the wheels even in Neutral when rear is on jackstands. Then the speedo will read that.
That does happen specially with tight Low Stall converters
Re: Speedometer question [Re: NachoRT74] #173079
12/23/08 12:02 PM
12/23/08 12:02 PM
SPWC Offline OP
SPWC  Offline OP
So is it the same with Manual(Non Automatic) transmissions? I suppose it would be fronm the input shaft spinning
Re: Speedometer question [Re: SPWC] #173080
12/23/08 03:54 PM
12/23/08 03:54 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
ooops, I didn't take care about was MANUAL LOL...
PROBABLY the same?
