Ross 440 flat top pistons 82008 valve reliefs #1730030
01/14/15 10:26 PM
01/14/15 10:26 PM
NE
LimeRT Offline OP
LimeRT  Offline OP
NE
Can anyone tell me the valve relief pocket depth on these pistons?Thanks Dustin
Re: Ross 440 flat top pistons 82008 valve reliefs [Re: LimeRT] #1730031
01/15/15 01:27 AM
01/15/15 01:27 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The right answer is a phone call away !
Please call us or email us for price quotations and recommendations for your application. We are more than happy to assist you in any way.
ROSS Racing Pistons
625 S. Douglas Street
El Segundo, CA 90245
Tech Line 310 536 0100
Re: Ross 440 flat top pistons 82008 valve reliefs [Re: 62maxwgn] #1730032
01/15/15 01:47 AM
01/15/15 01:47 AM
NE
LimeRT Offline OP
LimeRT  Offline OP
NE
I'm looking at different pistons for a build and was looking for a stocking piston that has plenty of valve relief otherwise I'm looking at custom pistons which the guy I'm building for gave me a budget and I have a fairly short time frame.
Re: Ross 440 flat top pistons 82008 valve reliefs [Re: LimeRT] #1730033
01/16/15 12:41 PM
01/16/15 12:41 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Well it says good to .650 lift cam and they usually give the safe quote on that.
http://www.summitracing.com/int/parts/ros-82008
what lift cam, heads and how much off heads?
Re: Ross 440 flat top pistons 82008 valve reliefs [Re: LimeRT] #1730034
01/16/15 01:13 PM
01/16/15 01:13 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Going from memory (but I, too, suggest calling Ross for the specs):
Int - .220"
Exh - .200"
You should probably ask them what the cutter diameters are, too, in case you're running valves much bigger than the common 2.19" / 1.81" for some reason.
