M28 Code for 1971 E Bodies #1729641
01/14/15 01:12 PM
01/14/15 01:12 PM
Chicago Blackhawks
hemicar1971 Offline OP
Chicago Blackhawks
M28 Code---front bumper periphery
-What got put on an E Body with this option.
-Did M28 make it onto the fender tag of a 1971 E Body.
-I have seen it on a 1971 Challengers fender tag but I have some questions about that tag being made up.
1971 HEMI E BODY REGISTRY
Re: M28 Code for 1971 E Bodies [Re: hemicar1971] #1729642
01/14/15 02:16 PM
01/14/15 02:16 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Stand alone option.
It's on my tag and sheet. IIRC, its up with the M codes 2 line from top. Like where they are in the green stripe 71 being discussed now.
I have other examples on tags too. Don't have access to those pics right now though. The cars that have then typically have other molding options, like A46, but that is just coincidence. They tend to be cars optioned up some.
I have tag info on two A78 cars with M28. And the loaded Juliano sunroof car has M28. My car has it and it's not an A78 either. All 4 of those are A46 though. That's just 4 cars off the top of my head.
Re: M28 Code for 1971 E Bodies [Re: autoxcuda] #1729643
01/14/15 03:08 PM
01/14/15 03:08 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I posted a blue R/T A78 with M28 periphery molding tag here:
https://board.moparts.org/ubbthreads/show...rt=all&vc=1
Re: M28 Code for 1971 E Bodies [Re: autoxcuda] #1729644
01/14/15 03:14 PM
01/14/15 03:14 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Another M28 tag on a loaded 383-2bbl car here:
https://board.moparts.org/ubbthreads/showflat.php?Number=4691451
Re: M28 Code for 1971 E Bodies [Re: autoxcuda] #1729645
01/14/15 03:23 PM
01/14/15 03:23 PM
Chicago Blackhawks
Chicago Blackhawks
Stand alone option. So what parts are put on a Challenger once someone by ordering a car and the M28 Option is generated. If it is a stand alone option then it will have nothing to do with other options such options as in the M moulding options. I have seen it on a few Challenger fender tags but that is just a letter and a number put together. What I am asking it what are the exact parts or pieces that this code is referring to that are put on a Challenger.
Re: M28 Code for 1971 E Bodies [Re: hemicar1971] #1729646
01/14/15 04:24 PM
01/14/15 04:24 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
It was three pieces of wide trim around the headlight buckets & front of the hood to give a Challenger a 'loop bumper' appearance.
Re: M28 Code for 1971 E Bodies [Re: Alaskan_TA] #1729647
01/14/15 05:39 PM
01/14/15 05:39 PM
Chicago Blackhawks
Chicago Blackhawks
So Barry that is all that is on this option M28. Could the Wide Hood and Fender Moulding been ordered with any other options or group of an options via the A codes. It looks like everyone has said it is a stand alone code. Just asking this because I know of a car with the wide hood moulding and is not coded for it on the fender tag, have not seen the broadcast sheet. I also looked at a 1971 Cuda years and years ago that had power windows and it was not coded on the fender tag but on the Broadcast Sheet. I did not go back and take a second look to buy the car after seeing that is was not coded on the Fender Tag.
I also find it odd that Chrysler double coded some options like the Spoilers both front and rear. A45 and then code J68 and J81 and then only code rubber bumpers on the Broadcast Sheet. I guess you would of had to work in Office of Chrysler to understand why some things were done.
Thanks for Answering.
Re: M28 Code for 1971 E Bodies [Re: hemicar1971] #1729648
01/14/15 06:53 PM
01/14/15 06:53 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
It is definitely a standalone code, though as others have pointed out, the M28 is often ordered with the A46 'SE' moulding package and rocker mouldings.
In my experience, the M28 should always be on the tag as the body department needed to drill holes in each fender and in the hood to mount the moulding.
It is possible that the car you know had the moulding put on later by the dealer. A buyer could have ordered A46 and figured that they were getting everything, until such point as the car was delivered.
Otherwise, with Chrysler, anything was possible.
Re: M28 Code for 1971 E Bodies [Re: YYZ] #1729649
01/14/15 06:57 PM
01/14/15 06:57 PM
YYZ Offline
YYZ  Offline
As for exact parts and pieces, there would be:
3 'wide chrome' potmetal pieces - 2x fender, 1x hood
6 black plastic retainer clips to locate the fender mouldings
Attaching hardware (panhead screws for the fenders, short, bright green hex head machine screws for the hood piece with 3 dimples each, and speed nuts for the studs on the hood piece)
And if the car had a stripe, the part number was different for M28 cars -- the front was just a bit shorter to accommodate the moulding.
Re: M28 Code for 1971 E Bodies [Re: YYZ] #1729650
01/14/15 07:01 PM
01/14/15 07:01 PM
YYZ Offline
YYZ  Offline
Here are the clips for the fender pieces
Re: M28 Code for 1971 E Bodies [Re: YYZ] #1729651
01/14/15 07:06 PM
01/14/15 07:06 PM
YYZ Offline
YYZ  Offline
And the correct screw for the hood piece
NOS these have a bright green phosphate coating (or similar) on them
Re: M28 Code for 1971 E Bodies [Re: YYZ] #1729652
01/14/15 07:38 PM
01/14/15 07:38 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
You could not get M28 and rubber bumpers.
Not sure if it's called out that you couldn't get N94 fiberglass hood with it either. I have a feeling the vertical studs in the center piece molding will not be long enough.
Re: M28 Code for 1971 E Bodies [Re: hemicar1971] #1729653
01/14/15 08:32 PM
01/14/15 08:32 PM
MG, Brazil
v8punch Offline
v8punch  Offline
MG, Brazil
1971 Challenger
Re: M28 Code for 1971 E Bodies [Re: v8punch] #1729654
01/14/15 08:52 PM
01/14/15 08:52 PM
Chicago Blackhawks
Chicago Blackhawks
Do you have any other pictures of the Challenger v8 punch.
Re: M28 Code for 1971 E Bodies [Re: hemicar1971] #1729655
01/14/15 09:10 PM
01/14/15 09:10 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
and/or the emissions label from the driver's quarter window?
Re: M28 Code for 1971 E Bodies [Re: hemicar1971] #1729656
01/15/15 08:00 PM
01/15/15 08:00 PM
MG, Brazil
v8punch Offline
v8punch  Offline
MG, Brazil
hundreds... what do you whant to see?
Re: M28 Code for 1971 E Bodies [Re: v8punch] #1729657
01/15/15 08:09 PM
01/15/15 08:09 PM
Chicago Blackhawks
Chicago Blackhawks
Me I like to see the general pictures of the Challenger but 6bblgt asked if you had pictures of the emission stick on the back window. Just the usual pictures side front back engine and interior. Myself and others like cars that are not restored to death and are somewhat original but what ever condition the Challenger is in the pictures is ok with me.
Re: M28 Code for 1971 E Bodies [Re: hemicar1971] #1729658
01/15/15 08:30 PM
01/15/15 08:30 PM
MG, Brazil
v8punch Offline
v8punch  Offline
MG, Brazil
Photos when I bought the car(found on ebay). Had some minor changes as 15 inch wheels, intake manifold and carburetor exchanged ...
Re: M28 Code for 1971 E Bodies [Re: v8punch] #1729659
01/15/15 08:34 PM
01/15/15 08:34 PM
Washington/Las Vegas
1971 Gran Coupe Offline
Nice pictures!! Thanks for sharing.
Re: M28 Code for 1971 E Bodies [Re: v8punch] #1729660
01/15/15 08:40 PM
01/15/15 08:40 PM
Chicago Blackhawks
Chicago Blackhawks
Nice Challenger, I love that cheapie mirror on the drivers door. Wish I had of kept that mirror on my 1971 Challenger Convertible. Thanks for posting.
