Thoughts on 372" sb requested.
#1729588
01/14/15 05:55 AM
01/14/15 05:55 AM
Posts: 72 San Angelo, Texas
Cevidicus
San Angelo, Texas
A friend has this 372" small block that's built and ready to go. I just want to get some thoughts on its power potential and what could be expected from it in say a 3400lbs a body. All thoughts and criticisms welcome. I just want to know what y'all think its capable of. Thanks!
372" 340 block .030 over, 360 cast crank with mains turned down to fit, eagle rods, KB hyperutectic pistons,12.5:1, W2 heads ported and flowed 290, Mopar 1.5 roller rockers, Howards solid .599/.620 solid cam, Holley strip Dom intake
Re: Thoughts on 372" sb requested.
[Re: Cevidicus]
#1729589
01/14/15 11:04 AM
01/14/15 11:04 AM
Posts: 52,972 Romeo MI
MR_P_BODY
That would be about 520hp... JMO
[Re: MR_P_BODY]
#1729590
01/14/15 11:36 AM
01/14/15 11:36 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Haven't seen good luck with 360 cranks in 340s. Should be a stout motor, high tens if you max the combo.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1729592
01/14/15 11:44 AM
01/14/15 11:44 AM
Guitar Jones
I agree on the 10's. I don't know about the crank but I'd think if you kept the RPM's under 7000 it would probably hold up.
[Re: J_BODY]
#1729593
01/14/15 11:51 AM
01/14/15 11:51 AM
MR_P_BODY
Cast crank with mains turned down makes me cringe...... but I'll wait for more knowledgeable folks to kick in.
In 73 the 340 had a cast crank... it was just the 1 year then the 340 died
[Re: MR_P_BODY]
#1729594
01/14/15 12:11 PM
01/14/15 12:11 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
MP/Scat sells a 3.58 stroke 340 main cast crank.
Should be in the 10s...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#1729598
01/14/15 03:39 PM
01/14/15 03:39 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
A buddy of mine was going to do this SAME combo. "Poor Man's Stroker"? Well, not so much. GOOD shops were quoting him $500 and up to cut and re heat treat the crank. Bought that MP/SCAT from Jegs for $360-ish.
[Re: Cevidicus]
#1729599
01/14/15 03:49 PM
01/14/15 03:49 PM
Posts: 1,532 off the grid
340B5
off the grid
Get a good crank and use a lot of converter. 10.90's maxed out w/4.86 gear.
Yeah, it's got a smallblock.
[Re: Cevidicus]
#1729600
01/14/15 08:13 PM
01/14/15 08:13 PM
Posts: 149 N. Of Detroit, Mi
733404spdCuda
N. Of Detroit, Mi
My Combo built by MRL Racing
340 Block 4.100" 3.58 Eagle Crank 2.100 Eagle sbc H Beam rods Diamond Piston 9.7 comp Edelbrock 63CC Heads CNC ported my MCH Houghs 1.6 roller rockers Solid 243/251 duration @ .050" .550/.570 lift Edelbrock RPM Intake Kevco pan with baffles 750 quickfuel carb
520HP @ 6200 and 490TQ @4500 on pump gas
Nice street / strip motor
[Re: cudadoug]
#1729603
01/15/15 05:14 PM
01/15/15 05:14 PM
Posts: 11,586 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
2250# door car. 9.40s, 30s on a good day. 142-143 MPH. 7200-7400 RPM. 360 crank cut with no other work other than balanced.
I fought rod bearing issues for a long time before doing some work on the oil system. Still had to do bearings at 120 runs, but that's about what I put on it in a year. Just freshen it up over the winter and put it back in.
That was a while ago. Wouldn't do it again with the parts that are available now unless it would maybe be a nice street deal with less RPM. Inexpensive cubic inches.
