Comp cam pro magnum roller rockers - 440 stroker #1729425
01/13/15 09:43 PM
01/13/15 09:43 PM
North Jersey
dave73chally Offline OP
North Jersey
Anyone run the Comp Cams pro magnum roller rockers for a big block? I�m looking at a set for my setup. I'll be running 440 source stealth heads, lunati hydraulic roller cam on a 512 stroker. Part # is 1621-16. Summit has them as a set for $690 but I�ve seen them cheaper.
As far as the comp cams pro magnum go, I priced out the parts individually and it was a significant savings. What am I missing?
1077-2 Rocker Arm Shafts $93
1621L-1 Comp Cams Ultra Pro Magnum Rocker Arms (Left) $36 each
1621R-1 Comp Cams Ultra Pro Magnum Rocker Arms (Right) $36 each
1321SP-1 Comp Cams Rocker Arm Shaft Spacers $5 each
1321H-1 Comp Cams Rocker Shaft Retainers & Bolts $56
TOTAL: $477
KIT TOTAL: $694
Re: Comp cam pro magnum roller rockers - 440 stroker [Re: dave73chally] #1729426
01/13/15 10:08 PM
01/13/15 10:08 PM
call my pal Todd at Marsh Perf and check out all your options--He has some PRW's that would work for that and he has the comps in stock--best price
Re: Comp cam pro magnum roller rockers - 440 stroker [Re: dave73chally] #1729427
01/13/15 11:26 PM
01/13/15 11:26 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
TOTAL: $477
KIT TOTAL: $694
Might want to check your math
Re: Comp cam pro magnum roller rockers - 440 stroker [Re: BSB67] #1729428
01/14/15 02:32 AM
01/14/15 02:32 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
you need a total of 16 rockers !!!
