Re: Overcharging question
[Re: Dusted_Ya]
#172936
12/22/08 04:01 PM
12/22/08 04:01 PM
Posts: 18,424 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Do you have the two original ammeter wires hooked togeather? How is the ammeter wired? Hooking the voltmeter on that circuit will cause a drain on th battery as the voltmeter will be hot all the time.
The correct way to do the install is to hook both original ammeter wires togeather. Wire the voltmeter Black negative to chassis and red 12 volt to a keyed source.
[Re: Dusted_Ya]
#172941
12/23/08 11:47 AM
12/23/08 11:47 AM
So far as the "voltmeter pegging" there is no such thing as "unregulated output" from your alternator. All cars will measure a SLIGHTLY higher voltage at the alternator output post than they do at the battery, this is because there is resistance in the factory wiring. YOU WANT THIS AS LOW AS POSSIBLE. Higher readings can be caused by a number of things, mostly related to old wiring/ connectors and too-small wiring, and the ever present, ever troublesome, bulkhead/ firewall connector.
You must have a good regulator
You must have a good battery
You must have a VERY low resistance ground path all the way from the neg. batt. post to the frame/ body/ engine/ alternator/ regulator
you must have a VERY low resistance path from the battery pos/ feed/ wiring/ bulkhead/ ignition switch/ supply to the regulator.
Any of this wiring or connections will cause an overcharge condition.
So far as your voltmeter, all you've done wrong is hooked it up to cause a constant drain. If you park the vehicle long enough, it will eventually drain the battery.
