disc brake ???? #172891
12/22/08 01:26 PM
12/22/08 01:26 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Hey looking at some 14x6 old school mag wheels. Should i be concerned about them fitting over the disc brakes? (They are the standard 74-75ish a-body style I think)
Re: disc brake ???? [Re: Mr.Yuck] #172892
12/22/08 01:31 PM
12/22/08 01:31 PM
73-76 A body 10.87 rotors/stock calipers you're good. Hope the offset is right for you
Re: disc brake ???? [Re: RapidRobert] #172893
12/22/08 01:36 PM
12/22/08 01:36 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
just in case they are bigger, what's the biggest rotor I can use?? Here are the wheels.
Re: disc brake ???? [Re: RapidRobert] #172894
12/22/08 01:44 PM
12/22/08 01:44 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
I wouldn't say your good, but chances are good. I have seen problems in the past with the way the backsides of some rims are made. It's not a dia. problem but a caliper to the center area of the rim problem. If it's not square enought there it will clip the leading edge of the caliper.
Re: disc brake ???? [Re: Mr.Yuck] #172895
12/22/08 01:45 PM
12/22/08 01:45 PM
The 11&3/4" larger stock setup needs 15" wheels
