Threaded inserts #1728452
01/12/15 09:26 PM
01/12/15 09:26 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Is there a special application for using threaded inserts in fiberglass to keep them from loosening up over time?
Fastest 300
Re: Threaded inserts [Re: Crizila] #1728453
01/12/15 11:25 PM
01/12/15 11:25 PM
moparx Offline
moparx  Offline
what are you planning to mount ?
Re: Threaded inserts [Re: moparx] #1728454
01/13/15 01:18 AM
01/13/15 01:18 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Fiberglass fenders to a fiberglass body.
Fastest 300
Re: Threaded inserts [Re: Crizila] #1728455
01/13/15 03:58 PM
01/13/15 03:58 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I would choose an insert specifically made for fiberglass, they have ribs or knurling to prevent them from spinning.
http://www.stl-vettes.com/65Vette/corvette_Misc/Images/Rivet_Nuts.pdf
Re: Threaded inserts [Re: John_Kunkel] #1728456
01/13/15 05:18 PM
01/13/15 05:18 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Thanks a lot John. I have the tool, just not the correct rivets for fiber glass. Also. Loctite makes a product called "Sherex Locsert". It has an adhesive that discharges around the outside of the insert after you install it. Ever heard of it? I know nothing about it, but I think it's for fiber glass.
Fastest 300
Re: Threaded inserts [Re: John_Kunkel] #1728457
01/13/15 11:12 PM
01/13/15 11:12 PM
moparx Offline
moparx  Offline
informative article john . what are the differences between nutserts for glass as compared to steel ?
Re: Threaded inserts [Re: Crizila] #1728458
01/14/15 12:14 PM
01/14/15 12:14 PM
E
earlymopar Offline
earlymopar  Offline
E
I don't understand why you need something special. If you're attaching fenders, there are literally thousands of fiberglass fendered cars using standard bolts with nuts and fender washers to distribute the load. If, you're looking to eliminate the nuts or have locations where the threads are "blind" and have no access to place nuts and washers, then your question makes sense.
- EM
Re: Threaded inserts [Re: earlymopar] #1728459
01/14/15 01:09 PM
01/14/15 01:09 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
- EM
Exactly my problem. Poor / difficult access in many areas.
Fastest 300
Re: Threaded inserts [Re: Crizila] #1728460
01/14/15 01:40 PM
01/14/15 01:40 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I think I would possibly try bonding nuts to the back of the panel. Those nut inserts are fine. I have used them many times, but on steel and aluminum. Fiberglass has a very low "spider" point. Meaning the glass will crack and spider-web out from pressure. Crimping those nut inserts in place could easily do this. Plus the nut inserts do not have a very large "foot print". They do not grab very much. It is dificult to get them tightly in place on steel, let alone glass. The more I think about it, the more I'd be inclined to glass some nuts and washers in place on the back sides of the panels. That is just my $1.250.
Re: Threaded inserts [Re: 70HemiGTX] #1728461
01/14/15 02:46 PM
01/14/15 02:46 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
might just go that route.
Fastest 300
Need Help ID'ing Mid-30's Fenders [Re: moparx] #1728462
01/15/15 11:44 PM
01/15/15 11:44 PM
CA - Lord help us!
GTXperience Offline
GTXperience  Offline
CA - Lord help us!
Can anyone help me ID these fenders? I know they are mid-30's but am not sure what exact year and if they are Dodge or Plymouth or for a pass car or truck. Any help would be appreciated. Thnaks in advance.
Re: Need Help ID'ing Mid-30's Fenders (Pic 2) [Re: GTXperience] #1728463
01/15/15 11:46 PM
01/15/15 11:46 PM
CA - Lord help us!
GTXperience Offline
GTXperience  Offline
CA - Lord help us!
Another pic
Re: Need Help ID'ing Mid-30's Fenders (Pic 2) [Re: GTXperience] #1728464
01/16/15 03:17 AM
01/16/15 03:17 AM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
Looks a lot like what was on a 35 Plymouth I had once. Should fit 35 & 36 Plymouth car. Think Dodge was slightly different, maybe longer. Gene
Re: Need Help ID'ing Mid-30's Fenders (Pic 2) [Re: poorboy] #1728465
01/16/15 08:32 PM
01/16/15 08:32 PM
dogdays Offline
dogdays  Offline
talk about hijacking a thread!
R.
Re: Need Help ID'ing Mid-30's Fenders (Pic 2) [Re: dogdays] #1728466
01/17/15 12:17 AM
01/17/15 12:17 AM
Freeport IL USA
Freeport IL USA
This afternoon this was in its own thread! See the title for the last 4 entries? Gene
Re: Need Help ID'ing Mid-30's Fenders (Pic 2) [Re: poorboy] #1728467
01/20/15 05:17 PM
01/20/15 05:17 PM
dogdays Offline
dogdays  Offline
Weird!
R.
