Re: Mandrel Exhaust Bender
[Re: DeMopuar]
#1728397
01/12/15 09:35 PM
01/12/15 09:35 PM
Posts: 8,398 Highland, MI.
Sunroofcuda
Highland, MI.
Good luck! The reason why mufflers shops don't have mandrel benders is they are VERY, VERY expensive, & the machines are very elaborate. Demand & recovery of cost don't jive.
[Re: Sunroofcuda]
#1728398
01/12/15 09:55 PM
01/12/15 09:55 PM
Posts: 75,047 U.S.S.A.
JohnRR
U.S.S.A.
The one shop near me has closed since the last time I had a system worked on ...
[Re: DeMopuar]
#1728399
01/12/15 10:10 PM
01/12/15 10:10 PM
Posts: 88 Germantown, WI
72RallyeGY8
Germantown, WI
I am just north of Milwaukee and have two places that I am going to look at. It probably won't be until the spring as the truck is now snowed in for the winter. One place is in West Bend and the other is in Sheboygan. I will have to dig up their contact information if you are interested. I have not had the truck in to quote yet, so I have no idea the pricing.
1972 Charger Rallye (GY8) 1978 Dodge D100 Stepside 1971 Dodge Superbee (GB2)
[Re: Jwilli500]
#1728402
01/13/15 05:13 PM
01/13/15 05:13 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
What are you working on?
you broke his post rule! he already knows what he's working on
[Re: mikemee1331]
#1728403
01/13/15 06:10 PM
01/13/15 06:10 PM
Posts: 15,424 Omaha Ne
TJP
Omaha Ne
[Re: John_Kunkel]
#1728405
01/13/15 07:00 PM
01/13/15 07:00 PM
JohnRR
U.S.S.A.
The question is pertinent since there are bolt-on mandrel-bent X-pipe systems available for many Mopars.
that is correct and unless he is doing something off the wall buying one is going to be cheaper than having it done locally , been there and have a $1000 exhaust system to prove it .
[Re: DeMopuar]
#1728406
01/13/15 07:05 PM
01/13/15 07:05 PM
moparpollack
Lil Herman
Lil Herman
85086
Harold should be able to build you what you need. http://www.furoracing.com/exhaust.shtml
[Re: TJP]
#1728409
01/13/15 09:23 PM
01/13/15 09:23 PM
moparpollack
Lil Herman
Lil Herman
85086
he wants non welded pipes. IE: Single piece with no sectioning /welding
It's central Wisconsin there isn't much there.
Still wondering what the application is?
[Re: Stanton]
#1728411
01/14/15 12:13 AM
01/14/15 12:13 AM
Posts: 516 ND
dodgedon
ND
Look up Heartthrob Exhaust INC. Litchfield MN. They are about 65 miles West of Minneapolis.
67 Charger 383 auto 75 Dodge CNT 800 CAT Diesel 2012 Ram Crew cab 5.7 4x4
[Re: DeMopuar]
#1728412
01/14/15 07:29 AM
01/14/15 07:29 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
Does anyone have a good experience with an exhaust shop that does mandrel bending? I'm looking at having a 2.5" setup installed on my car with an X pipe, etc.... They seem few and far between, but I really want a shop that can bend it -- not one that welds mandrel bent stuff together.
I'm located 4 hours from Chicago and 2.5 hours from Minneapolis in Wisconsin -- and the distance isn't the biggest pain, it's finding the right guy to do the work. I've seen photos of mandrel exhaust systems done right and they are gorgeous. Please don't try and talk me out of this -- I know what I want..........
Thanks all,
Mark
At least you are in a fairly populated area as far as car stuff goes. You WILL have to travel to find this unicorn, but it should be there if you do.
What I'D do is call/contact every exhaust company out there, you know, the ones that already offer these pre-made systems you dont want, and see if they'll make a one-off for you. It'll cost ya, but art is not cheap. If you are willing to pay for what is essentially their inconvenience (these companies dont make money on one-offs), i'd wager at least one will accommodate you. I'd start with the smaller companies first... The Pypes, Kooks, suppliers ov mandrel bends, etc, before you bug the big ones like Flowtech, Dynomax, Hedman, Flowmaster, etc. There are a lot ov these machines out there, and people are making pre-made systems with them. You just gotta convince one to work with you and whatever Ford GAA-engined 62 Dart stretch-limo you're working on.
Maybe sleuth out and track down the cars you've seen (and liked) in photos and find out where they got it done?
[Re: John_Kunkel]
#1728414
01/14/15 09:03 PM
01/14/15 09:03 PM
Posts: 1,106 Northeast
VincentVega
Northeast
Doesn't TTI make full mopar exhaust? get a 3" system and then it won't matter if it isn't mandrel bent. In fact I've seen comparisons where 3" tail pipes freed up like 25HP over 2.5. And I'd imagine they could be clamped together with the nice band clamps.
Our garage actually has a real hydraulic bender, up to 2.5". Not mandrel though. just shoes. good enough for us. You can pick up some neat stuff on the used market
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
