Exhaust Adaptor w/Bung?
#172816
12/22/08 07:50 AM
12/22/08 07:50 AM
Posts: 5,443 Indiana
YO7_A66
Indiana
Does anyone make an in-line adaptor that I can bolt into my existing 2-1/4" exhaust system that has a bung welded to it (non header type)? I would like to just cut out a section of my 2-1/4" exhaust and add a bung without having to go to a muffler shop in the middle of Winter. Thanks
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: Exhaust Adaptor w/Bung?
[Re: Mr.Yuck]
#172818
12/22/08 08:22 AM
12/22/08 08:22 AM
YO7_A66
Indiana
I am looking into "possibly" getting an LM1 kit this Winter. If I do, than I will need to add the bung and I am not running headers. I can weld but I do not have a welder at home and I do not want to drive the car in the Winter to the exhaust shop. So I was hoping to just find an in-line adaptor to mount so that I could do it this Winter in my garage. I would assume that the standard exhaust pipe wall thickness is too thin to tap thru for a bung, but that is just a guess. Thanks
[Re: Mr.Yuck]
#172820
12/22/08 11:06 AM
12/22/08 11:06 AM
Posts: 18,416 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
That's alot of trouble for very little gain
Thats not true. There could be lots to gain esp if he finds that extra mile or two per gallon. Depending on how much he drives the car he could pay for the LM1 and then put free extra cash in his pocket every time he fuels up. Then he can buy what ever he wants for free.
[Re: NITROUSN]
#172821
12/22/08 11:41 AM
12/22/08 11:41 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
mpg on a muscle car?? kinda like lipstick on a pig. You can tune a carb just fine w/ a vacuum guage.
[Re: Mr.Yuck]
#172822
12/22/08 11:59 AM
12/22/08 11:59 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I'll take the LM-1 any day for doing my WOT testing. As for the poster, just get the bung and wait till you get the car out to have it welded in(takes a couple of minutes).Its better if its welded in due to a possible air leak giving a false reading with a clamp on type
[Re: Mr.Yuck]
#172823
12/22/08 12:02 PM
12/22/08 12:02 PM
YO7_A66
Indiana
""Why do you need a LM1 kit? You could spend that cash on something nice for yourself...or car.""
Thanks for the opinion, but I am doing some investigation to determine if I think it would be good tool for my garage.
I might just call my local exhaust shop to see if they will make exactly what I would need. Thanks
[Re: Mr.Yuck]
#172827
12/22/08 12:22 PM
12/22/08 12:22 PM
MR_P_BODY
didn't mean to offend anybody here...just at $350+ plus what ever the exhaust shop is going to charge, for an mild muscle car I don't see the value. As for a racer, or a boosted car it is a good thing to have. I used a similar product on a boosted 440 I ran. You kinda need it so you don't start burning up things. I just don't know how much of a gain you are going to see using that set-up on an older, mild big block. You'd probably be able to come almost as close tuning the "old fashion" way.
You didnt offend me. But with the LM-1 you can dial in the total range of the fuel curve. I'm a old hard core vac kinda guy also but the LM-1 will record the idle cruise and wot so you can go back and adjust what needs to be corrected
[Re: ZIPPY]
#172830
12/22/08 02:05 PM
12/22/08 02:05 PM
MR_P_BODY
Zippy, does that unit have the ability to record and keep data during a run, I didnt see any where that it did(but I didnt read it all). That one would work well for my drag stuff
[Re: MR_P_BODY]
#172831
12/22/08 02:24 PM
12/22/08 02:24 PM
Posts: 2,826 NY usa
540challenger
NY usa
It say it can store up to 2 hours worth of data. not just Fuel-air ration but rpms and etc.
"etc.= i forgot what else and didn't want to reread."
[Re: MR_P_BODY]
#172833
12/23/08 04:54 PM
12/23/08 04:54 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
if you want bungs on the cheap, pick up a set of spark plug anti-foulers and cut the ends off. it's the same thread as an O2 sensor
[Re: patrick]
#172834
12/23/08 05:07 PM
12/23/08 05:07 PM
i have a friend that works at a muffler shop and he gave me a section of exhaust pipe with the bung in it. he had removed it from a car he was putting an exhaust on. even flaired it for me.
I just got my LM-1 hooked up and working when the weather got COLD. But i cant wait to run this car down the track and see what my mixture at WOT looks like.
BTW, i had initially set my idle mixture with a vacuum gauge and it turns out, I was pretty much dead nuts on. but WOT still needs looking at!
