Drum to Disc brake conversion #1728152
01/12/15 04:39 PM
01/12/15 04:39 PM
Indiana
dragracer1 Offline OP
Indiana
I am trying to go from stock drum brakes on my 74 Scamp to aftermarket race brakes for my 8.75 rear end. I currently have Strange 35 spline axles. I have tried Wilwood 2.36 offset and now aerospace 2.29-2.45 offset and the hat/rotor still hits the caliper mount. I measured my offset and I have 2.1375 offset. I called strange engineering and they said that they do not make an a-body axle that would work for this application to get the right offset, they said i'd have to get e-body axles made. I cant be the only one in the world that has ever tried to do this and ran into problems. I have a stock with a-body 8.75, spring re-locator kit using Bogart Racing 10" wheels with a 7 3/8 back space.
Any help would be greatly appreciated!
Re: Drum to Disc brake conversion [Re: dragracer1] #1728153
01/12/15 06:42 PM
01/12/15 06:42 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Do you mean standout? Stock A-body standout is 2.25" measured from the end of the housing to the outside of the axle flange.
Re: Drum to Disc brake conversion [Re: John_Kunkel] #1728154
01/12/15 11:50 PM
01/12/15 11:50 PM
Indiana
Indiana
I mean the axle offset, measured from the outside axle housing flange to the outside of the axle face (hub)....i checked it with a digital caliper and it is 2.1375 (Deminsion F on the strange order form) http://www.strangeengineering.net/website/wp-content/uploads/2013/11/Axle-Order-Form.pdf
Has anyone used aerospace disc brake converting from drums on an a-body and if so, how did u get the brake hat/rotor to caliper brake right?
Re: Drum to Disc brake conversion [Re: dragracer1] #1728155
01/13/15 01:35 AM
01/13/15 01:35 AM
Western Md.
skicker Online tonguue
"The Champ"
skicker  Online Tonguue
"The Champ"
Western Md.
The fact that the axles are in an A body rear may be the problem if you ordered the 35 spline axles for an A body housing. I thought the bell drum design and backing plates used on the 8 3/4 A body housings (4" bolt pattern)was an oddball all to itself. I would call or p/m Doctor Diff. If anyone can hook you up or at least let you know whats wrong it will be Cass.
...FAFO...
Re: Drum to Disc brake conversion [Re: dragracer1] #1728156
01/13/15 04:20 PM
01/13/15 04:20 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The common term for that is "standout" and yours isn't consistent with any factory dimension....A-body SBP standout is 2.25" and BBP is 2.500".
Re: Drum to Disc brake conversion [Re: John_Kunkel] #1728157
01/13/15 08:31 PM
01/13/15 08:31 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Wilwood and other companies do not design rear brakes correctly for Mopar applications. They consider axle flange stand out to be 1/8" less than what it actually measures because they never took into account the thickness of the drum brake backing plate when they "designed" the caliper brackets.
In other words, 5 x 4" bolt pattern A-body axles measure 2.1" from the inside of the wheel bearing snap-ring, to the outside of the axle flange. This is what they mistakenly call "offset".
BTW, as far as I know, I'm the only source for a rear disc brake kit that fits Mopar axles with 2.225" stand-out.
