As someone who's been there, you should check into having a custom cam ground for it.
I made the mistake of using a Mopar Performance 524/292 hydraulic cam in my 572 Hemi.
I used it because I already had it.
I bought it because I got a deal on it, $100 for a brand new Hemi cam kit.
It's waaay to small and being a hydraulic adds other issues if you plan on having it rev past 5500.
I ordered a custom ground solid lifter (flat tappet) cam from Dwayne Porter, Comp Cam and it took about two weeks to get it.
Dwayne spec'd out the cam based on all the info on my engine, drivetrain, the car and my intended driving use. A street car that gets raced.
With Nitriding the cam it was $320 delivered.
I talked to several cam suppliers before I ordered the cam.
Bullet spec'd out something similar to the one I ordered from Dwayne. It had just a little more lift and similar duration.
I still need to get the EDM solid lifters and new springs so I can install it.
There's never enough money at Christmas time.
Get a cam designed for your build.
Yours is 100 cubic inches smaller than mine, but you don't want a dyno sheet with a power band that looks like mine.
