rim blow steering wheels #172781
12/22/08 02:06 AM
12/22/08 02:06 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
if I were to buy a rim blow steering wheel peice be peice, what do I have to all be looking for? any info is greatly appreciated!
-kevin
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: rim blow steering wheels [Re: mopars_1] #172782
12/22/08 01:04 PM
12/22/08 01:04 PM
Edmonton , Alberta , Canada
stwheels Offline
stwheels  Offline
Hi Kevin, you of course need the wheel itself, the appropriate center cap for your application, a reproduction rim blow switch, a ground wire and a Black plastic spoke end cover and screw for the front of the bottom spoke where the switch ends are located.
There are 3 center caps, The one shown is for Plymouth in 1971, another 1970 version is identical but has a Barracuda emblem in the middle and then there is Dodge version without the 3 fake allen head bolts but with a metal band on the front face of the Black rubber that has the word "DODGE" stamped in it twice.
Re: rim blow steering wheels [Re: stwheels] #172783
12/22/08 01:05 PM
12/22/08 01:05 PM
stwheels Offline
stwheels  Offline
Here's a shot of the rear showing the ground wire.
Doug Lepak
Re: rim blow steering wheels [Re: stwheels] #172784
12/22/08 01:10 PM
12/22/08 01:10 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
..........And you will need the correct steering wheel column adapter depending on which vehicle you plan on installing it on.
Re: rim blow steering wheels [Re: ScottSmith_Harms] #172785
12/22/08 01:19 PM
12/22/08 01:19 PM
stwheels Offline
stwheels  Offline
Yep, what Scott said. If the wheel is going on an A or B body that had a standard wheel mounted with a splined shaft you would need one of the adapters. This would be a smooth sided adapter.
If the wheel is going on any E body it's just a matter of bolting it on the crush can corrogated adapter that will already be in place.
This picture shows the Dodge center cap and the E body only adapter.
Doug Lepak
Re: rim blow steering wheels [Re: stwheels] #172786
12/22/08 01:52 PM
12/22/08 01:52 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Doug,
Did you get the photos I sent for my 68 wheel?
John
Re: rim blow steering wheels [Re: rrunner] #172787
12/22/08 02:31 PM
12/22/08 02:31 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
thanks for all the info guys! I wanted a rim blow for my 71' roadrunner, and wasn't quite sure what I was getting myself into. thanks again!
1937 Plymouth PT50
Re: rim blow steering wheels [Re: rrunner] #172788
12/22/08 03:35 PM
12/22/08 03:35 PM
stwheels Offline
stwheels  Offline
Doug,
John
Hi John, e-mail sent!
Doug Lepak
Re: rim blow steering wheels [Re: stwheels] #172789
12/22/08 08:03 PM
12/22/08 08:03 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
look for a wheel with the 3 spokes in close to mint condition...all the other stuff,switch,wire,end cover,center caps are all available now....and then u can pick and choose who u want to restore it....heck, just get the wheel...they can steer you over to the other parts that they don't have/sell....doug did a great job on mine...
Re: rim blow steering wheels [Re: AARCONV] #172790
12/22/08 10:03 PM
12/22/08 10:03 PM
Long Island NY
ErikR Offline
ErikR  Offline
Long Island NY
another detial to look out for would be the dish of the rimblow wheel. Based on a post here awhile ago I think it was shown that there was a difference in the dish of 1970 and 1971 wheels with the same part number. I know I saved some reference pics but it's on a drive packed away. FWIW I do have 2 rimblows with different dish in the wheels.
Re: rim blow steering wheels [Re: ErikR] #172791
12/23/08 12:11 AM
12/23/08 12:11 AM
WOODGRAINWHEELS.COM Indiana
plumbeeper Offline
plumbeeper  Offline
The difference in the depth of the spokes is all just high production manufacturing at it's best. There is no reason there would be an intended difference since they made an adapter to compensate for the depth. I've seen this posted a few times and still no consistant documented proof that it was intentional.
Re: rim blow steering wheels [Re: plumbeeper] #172792
12/23/08 12:16 AM
12/23/08 12:16 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I believe it was completely random
Re: rim blow steering wheels [Re: plumbeeper] #172793
12/23/08 12:28 AM
12/23/08 12:28 AM
plumbeeper Offline
plumbeeper  Offline
All of the items Doug listed are needed as well as the one item that gives the wheel it's signature name "The Rimblow Switch"
We have all of the items you need, in stock and ready to ship. Rimblow wheels as well as all of the Mopar woodgrain wheel are all we do.
Re: rim blow steering wheels [Re: plumbeeper] #172794
12/23/08 01:35 AM
12/23/08 01:35 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
dave, you are an awsome guy! my dad had you redo a rim blow steering wheel for his boss mustang and it turnd out GREAT. If I get a wheel that has a crack in it, you will be getting my buisness thanks everyone for the great info!
1937 Plymouth PT50
Re: rim blow steering wheels [Re: stwheels] #172795
12/23/08 01:55 AM
12/23/08 01:55 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
one more question, was the button suppose to be color keyd to the rest of the interior? my interior for the 71 roadrunner will be gold if that makes a difference. thanks!
1937 Plymouth PT50
Re: rim blow steering wheels [Re: mopars_1] #172796
12/23/08 05:50 AM
12/23/08 05:50 AM
the house on the left.
cogen80 Offline
cogen80  Offline
so whats a used rim blow that is in decent shape but sure not show quality going for these days? i have one laying around from a 71 a-body and just wondering.
Re: rim blow steering wheels [Re: cogen80] #172797
12/23/08 08:52 AM
12/23/08 08:52 AM
NJ
EV2RTSE Offline
EV2RTSE  Offline
NJ
If the spokes are good, probably $200-$250 for the wheel by itself, add another $150-$200 if you have a nice center cap to go with it.
Re: rim blow steering wheels [Re: stwheels] #172798
12/23/08 08:40 PM
12/23/08 08:40 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
does anyone know about the center cap? thanks
1937 Plymouth PT50
Re: rim blow steering wheels [Re: mopars_1] #172799
12/23/08 09:34 PM
12/23/08 09:34 PM
stwheels Offline
stwheels  Offline
New, the only color you could get was Black but now they are reproduced in several colors so it would be up to you as to what color you'd prefer.
Doug Lepak
Re: rim blow steering wheels [Re: stwheels] #172800
12/23/08 10:03 PM
12/23/08 10:03 PM
plumbeeper Offline
plumbeeper  Offline
I've seen several original Fishcaps and Dodge caps molded in the original factory color (black, red, burnt orange, green, blue)but never the 71 style. The Fishcaps and Dodge caps are being reproduced and can be molded into any color, I just need a paint code. The 71 style rubber pad is not being reproduced (we have way too many black ones)so it would need to be vinyl dyed, again I would just need a paint code.
Re: rim blow steering wheels [Re: plumbeeper] #172801
12/23/08 10:09 PM
12/23/08 10:09 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
What holds the fake allen bolts on the piece? Mine has tiny holes through them and isn't together anymore
Re: rim blow steering wheels [Re: Mopar-Al] #172802
12/23/08 10:21 PM
12/23/08 10:21 PM
plumbeeper Offline
plumbeeper  Offline
They originally had plastic tabs that were melted over to hold the cap together. We now use machine bolts that are hidden inside of the Allen heads so they won't break again.
