M1 intake for a 505 street stroker?
#1726938
01/11/15 02:46 AM
01/11/15 02:46 AM
Posts: 1,807 Mopar Country, Mi
ccdave
The Ultimate
The Ultimate
Mopar Country, Mi
I'm considering a M1 intake for my 505 ci RB engine I'm building. Anyone running one? The car and engine specs are as follows: E body 3:23 gear 727 with 9.5 PTC conv. 2800 stall Ported E heads 10.8 comp Hyd roller 245@ .050 dur / 540 lift Headers The car is not a race car but will see the strip occasionally
Re: M1 intake for a 505 street stroker?
[Re: ccdave]
#1726939
01/11/15 03:02 AM
01/11/15 03:02 AM
Posts: 1,472 Overland Park, KS.
Joshs68
Overland Park, KS.
You will like the EDDY RPM more. I have ran both, the M1 wasn't bad but the RPM is better. More low and mid range.
[Re: ccdave]
#1726943
01/11/15 08:49 PM
01/11/15 08:49 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Running the 4150 M1 on the 493.
iron heads, 0.530/260 @ 0.050 cam, makes enough torque to cook the 315 drag radials at will.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: OUTLAWD]
#1726944
01/11/15 09:02 PM
01/11/15 09:02 PM
Posts: 7,664 IN
ahy
IN
I run the M1 single plane on an Ed headed 496 B stroker in a '70E with 5 speed. EFI. 243@.50" cam and 3.23 rear. I am very happy with it plenty of torque for normal driving at 2000 RPM... even in overdrive. If I don't completely stomp it it will pull clean from 1400 RPM. It is a bit tall... just fits under my flat hood with short EFI throttle body and a moderate drop air cleaner.
[Re: ahy]
#1726945
01/12/15 03:21 AM
01/12/15 03:21 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Given that everything else about your build screams "torque monster", I think a single plane would be a mistake. You'd give away mid-RPM torque, and you don't have enough cam to make it up, up top where the M1 will shine. An Eddy RPM or the new Mopar high rise dual plane (RPM clone) seem like the natural best choice here. Also, most of the comparisons I've seen would suggest that the RPM isn't giving much away up top anyway.
[Re: Thumperdart]
#1726947
01/12/15 01:25 PM
01/12/15 01:25 PM
OUTLAWD
Metro Detroit
Doesn't make much vacuum with that cam, but have a 4 hole spacer to help the signal out (maybe I'll give a tapered spacer a shot), drivability is no worse than my mild high 12 sec small block Dart.
The 500" motors make so much bottom end, I don't think a dual plane is really needed.
The off the shelf 10" 3k converter flashed to north of 4k, the Dynamic 9.5 is about the same, so low speed drivability was never really an issue. Normally run 3.55's, a 30" tire and it's a somewhat heavy car...
[Re: Thumperdart]
#1726953
01/12/15 08:36 PM
01/12/15 08:36 PM
Posts: 6,563 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
My 493 makes over 500 ft/lbs from 2000 to 5000. Peaked at 600 @ 4000.
That was with an M1 with TBI and an MP509 cam. The only reason I changed the converter to a 2800 stall was because it idles at 1100 and it was banging the crap out of the drivetrain every time you shifted out of Park.
It's in a 4800 lb C-body and other than the harsh engagement it drove just fine with the stock converter and 2.76 gears. It has 3.23 now and the engine sounds happier at part throttle cruise.
Kevin
I`m guessing the TBI helped keep it nice and clean............
Well...
It was AWFUL at first. I knew just enough about EFI and O2 sensors to be dangerous to myself and others. 76 deg of overlap causes a lot of reversion which causes a lot of random misfires which will drive a closed loop system absolutely bonkers.
Fortunately while I may not be that smart, I know people who are.
My buddy while not familiar with the 950 Commander system, discovered pretty quick that it could be set to switch between Alpha Numeric and closed loop so we set it to run A/N under 1800 and played with the map until it was happy, much like you would with a carb. Happy was no where near stoic I might add.
Once the engine was past 1800 it cleaned up enough that it would tolerate closed loop again without going into yo-yo mode and it was good to go.
Kevin
[Re: Thumperdart]
#1726955
01/12/15 11:25 PM
01/12/15 11:25 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
I run the M1 and a 1050 Dominator on the street.My 440 likes it.Rocky
Chrysler Firepower
[Re: Thumperdart]
#1726956
01/12/15 11:46 PM
01/12/15 11:46 PM
Posts: 3,437 Dandridge TN
Dabee
Dandridge TN
Thank you.........I laugh(sometimes)when I hear about guys that can`t get a single plane to work on a fairly mild combo........kinda like t-rams do`t work down low. Get the carb clean and tune right and I`ll take the single almost always.........
What makes you think I said I can't get the single plan on my 511 to work right. It works fine. All I said was "If I did it again I would go with a duel plane". My car is street driven, has AC, PS, PB, weighs 4000 lbs, a GV and a small cam that runs out of steam around 5400. It's only turning 2400 RPM at 70 MPH thus no advantage in running a single plan.
