No oil pressure on startup....... techs? #172691
12/21/08 11:10 PM
12/21/08 11:10 PM
NM
74fish Offline OP
74fish  Offline OP
NM
My wife has a 2002 Durango. I was driving it yesterday and noticed the oil pressure gauge was at 1/4. I thought I better check the oil ( you never can tell) before I could stop ,the pressure dropped and bottomed out. I shut off the engine and stopped the car. I checked the oil, it was fine. I started the car and it took about 30 seconds for the pressure to come back up, it pegged at 1/4.
I ruled out the sender and concluded it was indeed losing pressure. I drained a qt of oil and put in a qt of lucas oil additive, changed the oil filter to see if that would help.
Pressure was way over 1/2, the engine was humming and not noisey like before. This morning I started the car, it took a little bit before the pressure came back up. It was well over 1/2 again.
My son a parts guy, thinks that the check valve on the oil pump is getting stuck.
Anyone have any ideas
Re: No oil pressure on startup....... techs? [Re: 74fish] #172692
12/21/08 11:18 PM
12/21/08 11:18 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
SURE SOUNDS like a sending unit to me.
Try putting a mechanical gauge on it to check this condition.
Re: No oil pressure on startup....... techs? [Re: dOoC] #172693
12/21/08 11:44 PM
12/21/08 11:44 PM
NM
74fish Offline OP
74fish  Offline OP
NM
We ruled the sending unit out. Can't mistake the sound of an engine with no oil .....
Re: No oil pressure on startup....... techs? [Re: 74fish] #172694
12/21/08 11:52 PM
12/21/08 11:52 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Sounds like a sludged up motor on its way out.
Re: No oil pressure on startup....... techs? [Re: NITROUSN] #172695
12/22/08 12:08 AM
12/22/08 12:08 AM
NM
74fish Offline OP
74fish  Offline OP
NM
I googled the problem and found quite a bit of sludged engine problems but the symptoms don't fit. You think a motor flush should be my first step?
Re: No oil pressure on startup....... techs? [Re: 74fish] #172696
12/22/08 12:29 AM
12/22/08 12:29 AM
N
NITROUSN Offline
NITROUSN  Offline
N
I think you are beyond a flush. What pressures did you get with a mechanical guage?
Re: No oil pressure on startup....... techs? [Re: NITROUSN] #172697
12/22/08 12:55 AM
12/22/08 12:55 AM
NM
74fish Offline OP
74fish  Offline OP
NM
Haven't checked it. The car doesn't burn any oil and it has only 60+ miles on it Do you think I should drop the pan?
Re: No oil pressure on startup....... techs? [Re: 74fish] #172698
12/22/08 01:06 AM
12/22/08 01:06 AM
federal way, WA
74chargr Offline
74chargr  Offline
federal way, WA
I bet it was your filter. Same thing happened to me with a fram filter. Have you seen how they are constructed? I won't buy another one. Napa/WIX only for me or some higher quality filter.
74 Charger SE 87 Shelby Lancer 80 1 ton bread box 71 Duster rest in pieces
Re: No oil pressure on startup....... techs? [Re: 74fish] #172699
12/22/08 09:59 AM
12/22/08 09:59 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
It's a bit involved to drop the pan, but that's what you'll probably be doing, and hopefully find a plugged screen and no crank damage yet. If you have the 5.9, you will not be the first to have the pickup plugged, and I suppose the 4.7's could do it too.
Re: No oil pressure on startup....... techs? [Re: 74fish] #172700
12/22/08 11:44 AM
12/22/08 11:44 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Could be the by-pass in the oil pump is stuck, which
means pulling the pan. Change the oil filter first
and if the same problem is there pull the pan
Re: No oil pressure on startup....... techs? [Re: MR_P_BODY] #172701
12/22/08 04:12 PM
12/22/08 04:12 PM
P
Paul_Fancsali Offline
P
Suggestion Change oil change to another brand of oil filter I had a sludged 360 that had a 1 inch of carbon built up under the intake. I started changing oil every 500-800 miles
I used Marvel Mystery oil or a qt of atf built up from 20-25psi at speed to near 55psi. Got rid of noise and solved the problem. Another 318 I had bought had zero due to plugged pickup. I had to clean out twice but got pressure back to normal with the purchase of new gasket set. Depends on the chance your willing to take, which to do as all that detergent can lead to plugged pickup tube/ If valve seal particles forget it You pull the pan
Re: No oil pressure on startup....... techs? [Re: Paul_Fancsali] #172702
12/22/08 11:02 PM
12/22/08 11:02 PM
NM
74fish Offline OP
74fish  Offline OP
NM
That's what I've been reading, clogged pickup. It seems that my Dodge Durango along with a few other models are prone to clogging the lubrication system, even with regular oil changes.
I think I'm going to try to flush the engine with seafoam or somthing like that a couple of times, keep a sharp eye on the oil pressure and use a synthetic ...... It definitly got better with the new oil filter. I sure don't want to drop that pan ...... unless I have to .... it's a 4 wheel drive...
Re: No oil pressure on startup....... techs? [Re: 74fish] #172703
12/22/08 11:08 PM
12/22/08 11:08 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
IF it is sludged up ... that sea-foam will just LOOSEN more of the garbage up and plug-the-pickup worse.
GET a read with a REAL gauge and be prepared to pull-the-pan.
Re: No oil pressure on startup....... techs? [Re: dOoC] #172704
12/23/08 02:17 AM
12/23/08 02:17 AM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
You didn't say what engine, I'm going to assume you have the 4.7, I have done a few of those for the pickup clogging. You did the right thing in shutting it off right away. You wouldn't believe how many people come in and say "the oil light has been on for a week". They are the ones that usually need an engine. You might be ok, but I'd pull the pan before you start it again. If there's gritty sand like stuff in the pan,clean it out and replace the pickup tube.If there isn't you have other problems. The 4.7 is fairly easy to get the pan off.
Re: No oil pressure on startup....... techs? [Re: 10sec440] #172705
12/25/08 01:20 PM
12/25/08 01:20 PM
NM
74fish Offline OP
74fish  Offline OP
NM
Does anyone know the procedure for pulling the pan? It's a 4.7 4 wheel drive ..... Thanks for all the info everyone .....
Re: No oil pressure on startup....... techs? [Re: 74fish] #172706
12/25/08 01:47 PM
12/25/08 01:47 PM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
i dont know the complete procedure,but the first thing is to remove the front diff,driveshaft,6 bolts at eah half shaft/axle some bolts on eah side by the engine mounts and its out,that leaves the pan in the open
butch
Re: No oil pressure on startup....... techs? [Re: rhad] #172707
12/25/08 02:16 PM
12/25/08 02:16 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
4.7L oil pump is not in the pan. Its behind the timing gear, pan still has to come off for oil pick-up. Big job,if engine is sludged up a reman unit may be your next move. Oil changes every 3K are required.
