Re: Am I Doing Something Wrong? LCA Balljoint Issue...
[Re: RUNCHARGER]
#1726906
01/17/15 08:19 PM
01/17/15 08:19 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
I don't know how you'll keep it from spinning either, that's why I suggested a new Ball Joint a while back.
Sheldon
Makes sense. I must have overlooked your comment.
[Re: MuuMuu101]
#1726911
01/17/15 09:40 PM
01/17/15 09:40 PM
moparpollack
Lil Herman
Lil Herman
85086
The only way I ever cured a spinning ball joint is to put a jack under the lower ball joint and force the taper portion into he spindle until it stopped spinning. Stop being an engineer and start forcing thing like a mechanic.
[Re: MuuMuu101]
#1726913
01/17/15 09:46 PM
01/17/15 09:46 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Also, I'm having trouble removing the UCA ball joints from the spindle. I get the punch angled properly to pop the balljoint out with a hammer.
Hit the side of the spindle where the ball joint stud goes through, with a a couple times and it should pop loose.
[Re: OzHemi]
#1726914
01/17/15 09:46 PM
01/17/15 09:46 PM
moparpollack
Lil Herman
Lil Herman
85086
Bring it over and I can weld the ball joint stud to the ball joint so it won't spin.
That only works for upper ball joints!
[Re: OzHemi]
#1726915
01/17/15 09:49 PM
01/17/15 09:49 PM
moparpollack
Lil Herman
Lil Herman
85086
Yup use the force of the hammer!
[Re: moparpollack]
#1726916
01/17/15 09:52 PM
01/17/15 09:52 PM
OzHemi
Garden Grove, CA
Once I fire up the welder, it is hard to stop..
[Re: MuuMuu101]
#1726917
01/17/15 09:52 PM
01/17/15 09:52 PM
Posts: 4,323 NY NY
340duster340
NY NY
get a pickle fork and lube it up so you don't rip the boot. it will come right out.
or if you are coordinated enough a whack with a lump hammer directly to the top of the spindle should free it as well.
[Re: skicker]
#1726919
01/17/15 11:34 PM
01/17/15 11:34 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
ditto....Jack the lower BJ up into the control arm, unbolt it from the spindle and quit fooling with the upper BJ. Tighten the lower BJ up, put the cotter pin in and then put the 2 bolts in the spindle. Make sure you line the cotter pin hole up front to back!
To be fair, the LCA ball joint castle nut is a total PIA to get to with the UCA balljoint in place. Although, your way doesn't sound too bad either. So I'm assuming the cotter pin will be a PIA if the hole is facing wheel to frame rails?
[Re: OzHemi]
#1726920
01/17/15 11:34 PM
01/17/15 11:34 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
I'll be right over!
[Re: MuuMuu101]
#1726921
01/19/15 11:21 AM
01/19/15 11:21 AM
Posts: 5,102 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Correct. Sometimes its a huge pita to remove the cotter pin at a later time when it runs from frame to wheel. When the LBJ is unbolted from the spindle lift the spindle and UCA up out of the way and strap it up in the wheel well.
...FAFO...
[Re: MuuMuu101]
#1726922
01/19/15 11:53 AM
01/19/15 11:53 AM
Posts: 8,180 Detroit, MI
CokeBottleKid
Detroit, MI
So, I think I'm going to head over to HF to get a tap and die set. When I run the threads how should I hold the part so the center ball joint doesn't rotate as I'm utilizing the die?
Kid someone beat on that ball joint stud, return it and get a new one. You try to run a die over those threads and you'll most likely make it worse and then you can't return it.
