Page 3 of 4 1 2 3 4
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: 6PakBee] #1726883
01/11/15 04:14 PM
01/11/15 04:14 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Then you can remove the lower ball joint, stick it in your vise, and work on it without fighting anything.
DING DING DING!!!
It will take no more time to take it apart and do it right. If your worried about reassembly put the LBJ on the LCA first..jack it up into place and tighten it. Then bolt the two bolts from the spindle into the lBJ. Nothing says it has to go on the spindle first.
...FAFO...
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: Shoozy] #1726884
01/11/15 04:17 PM
01/11/15 04:17 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
None of us knew how to do it the first time. At least you're trying and learning.
This. JD nailed it.
A Good reminder
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: MuuMuu101] #1726885
01/11/15 04:43 PM
01/11/15 04:43 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Lovely, exactly what I wanted to do, take apart half the entire front suspension just to fix a new part. I'll buy a tap and die set next weekend and work on it. Is there an "easy" way to unseat the LCA and UCA ball joints from the spindle without using a pickle fork? And for the record, I did not hammer or file these ball joints.
If the stud is spinning in the LCA, the ball joint isn't set. Back off the torsion bar completely, jack the LCA up and the ball joint should just drop out. Then you can remove the lower ball joint, stick it in your vise, and work on it without fighting anything.
I already set the LCA in the ball joint to get the nut out and the Torsion bars are already backed off completely.
Then Runcharger is right on. Take a center punch, support the LCA so it can't move, whack the stud and it'll come right out. Without tightening the nut, that stud can't be set that tightly.
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: MuuMuu101] #1726886
01/11/15 05:30 PM
01/11/15 05:30 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
MuuMuu if you want to barrow a thread file and a die I am in Glendora close by. PM me if you want
"Just a Bracket car dressed up like a streetcar"
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: 6PakBee] #1726887
01/11/15 05:30 PM
01/11/15 05:30 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Ok, you have to take the ball joint off to repair the threads. The first thing I would check is did someone put a metric nut in the new ball joint box?????? Next, fixing the threads: a threading die has been mentioned, the proper item is what they call a HEX RETHREADING DIE. This die does not cut threads but straightens them , same with the tap, if you already have threads, you don't want to cut new ones, that just removes metal that you need for proper torque. Also use a RETHREAD TAP, It will straighten the thread without removing metal and clean the hole of debree..
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: rowin4] #1726888
01/11/15 06:00 PM
01/11/15 06:00 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Damn everyone is making this so hard. Grind or file the threads above the hole so the nut will go on.....These threads dont matter anyway as they aren't used.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: HemiRick] #1726889
01/11/15 06:24 PM
01/11/15 06:24 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Just did mine and had the same issue. Just filed the threads and it went on with no problem. Always a good idea to check threads by running a nut over the threads so if there's an issue it can be fixed before installation.
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: Just-a-dart] #1726890
01/11/15 08:01 PM
01/11/15 08:01 PM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
Sure thing. I'll pm you sometime this week as I don't know how my schedule is going to look.
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: MuuMuu101] #1726891
01/12/15 02:27 AM
01/12/15 02:27 AM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
I'm guessing you got a balljoint that someone F'd up and then returned saying it was good. Rockauto by chance? No worries, it can be fixed.
Its happened to all us at some point. We all had to learn the same way.
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: NV69B7RR] #1726892
01/13/15 12:59 AM
01/13/15 12:59 AM
SoCal
SoCal
Yeah, it's a Rockauto part...
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: MuuMuu101] #1726893
01/13/15 03:40 PM
01/13/15 03:40 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
For future reference run the nut on and off the stud by hand before installing. Just be sure everything works.
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: stumpy] #1726894
01/14/15 03:58 AM
01/14/15 03:58 AM
SoCal
SoCal
Thanks... I'll write it down and post it on my garage fridge.
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: MuuMuu101] #1726895
01/14/15 11:03 PM
01/14/15 11:03 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
If you put a sticky on the fridge for all the do's and don'ts you better get a bigger fridge...
...FAFO...
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: rowin4] #1726896
01/15/15 12:32 AM
01/15/15 12:32 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
This is what i ran into changing ball joints,metric nuts, did the same thing you are going thru, check with old nut for fitment. Had to use the old nuts, whitch where ok
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: skicker] #1726897
01/15/15 02:09 AM
01/15/15 02:09 AM
SoCal
SoCal
That could be arranged. More room for... and other tasties.
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: MuuMuu101] #1726898
01/15/15 11:51 AM
01/15/15 11:51 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
You guys might laugh but I requested a larger PC monitor at work because the old one wasn't large enough to hold all the sticky notes!
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: MuuMuu101] #1726899
01/17/15 07:35 PM
01/17/15 07:35 PM
SoCal
SoCal
Just removed the LCA Balljoint... No bend.
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: MuuMuu101] #1726900
01/17/15 07:36 PM
01/17/15 07:36 PM
SoCal
SoCal
One side...
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: MuuMuu101] #1726901
01/17/15 07:37 PM
01/17/15 07:37 PM
SoCal
SoCal
Other side... Bad picture.
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: MuuMuu101] #1726902
01/17/15 07:39 PM
01/17/15 07:39 PM
SoCal
SoCal
So, I think I'm going to head over to HF to get a tap and die set. When I run the threads how should I hold the part so the center ball joint doesn't rotate as I'm utilizing the die?
Page 3 of 4 1 2 3 4
