Page 2 of 4 1 2 3 4
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: MuuMuu101] #1726863
01/11/15 04:43 AM
01/11/15 04:43 AM
fredericksburg virginia
mopwrd340 Offline
mopwrd340  Offline
It looks like the top of the stud is bent like someone hit it with a hammer.
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: MuuMuu101] #1726864
01/11/15 04:44 AM
01/11/15 04:44 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
They can be flattened for two reasons. One because they are shorter (that's ok in that area). The other is that they are crushed (not ok). Clean the threads and try again...
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: Jim_Lusk] #1726865
01/11/15 09:02 AM
01/11/15 09:02 AM
Delaware
GeorgeH Offline
GeorgeH  Offline
Delaware
I agree with the above statements, the threads as they near the cotter pin hole don't look proper. Also looks like the top has been worked with a file or smacked pretty hard. Take the 2 bolts for the spindle out and drop the ball joint back out to look at it. If it's been hit hard likely to deform because of the cotter pin hole. Also , your stuff dirty for reassembly, or are those filings?. A squirt from a can of brake clean will clean things up. A lower ball joint is not something to take a chance on. If it's questionable at all,get another one. As said the nut should thread all the way down by hand.How ypou going to hold it to run a die down it? Do not score up the tapered seat.
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: GeorgeH] #1726866
01/11/15 11:06 AM
01/11/15 11:06 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Yep it's mushroomed on the end. Need a new ball joint. Since it's not a self locking nut you should be able to spin it all the way down with your fingers, then torque to spec and install the cotter pin.
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: ruderunner] #1726867
01/11/15 11:15 AM
01/11/15 11:15 AM
Andrews,In. U.S.of A.
67_Satellite Offline
A thread file or die will save that part. The thread damage isn"t that bad but must be adressed.
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: 67_Satellite] #1726868
01/11/15 12:08 PM
01/11/15 12:08 PM
NY NY
3
340duster340 Offline
NY NY
as mentioned above, i would just replace the part. well worth the $30 for the peace of mind, and lesson learned.
in time you will learn the "touch"
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: JDMopar] #1726869
01/11/15 01:14 PM
01/11/15 01:14 PM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
None of us knew how to do it the first time. At least you're trying and learning.
This. JD nailed it.
Old, tired, and sometimes broke down. Me, not my car...
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: MuuMuu101] #1726870
01/11/15 01:41 PM
01/11/15 01:41 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
It seems like the threads are flattened where the holes are for the cotter pins (hard to see in the picture). I'll ask my friend if he can bring a die next weekend.
There's a Harbor Freight tools where you live. Pick up an SAE tap and die set (they are usually like $35). You'll use it a zillion times anyway. Then you can get more work done. You'll probably want to take the joint off the arm (hit what it goes through method, or a puller) to chase the threads. Everything will be fine.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: goldduster318] #1726871
01/11/15 02:12 PM
01/11/15 02:12 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Muu Muu
1) Disassemble what you have done till the spindle can be moved to the workbench.
2) See if a file will clean up the threads so that you can spin the nut either by hand or with a small amount of resistance. If not replace the LBJ.
3) After you have it working or have replaced the LBJ, install the LBJ through the LCA. Make sure the slot for the cotter pin is facing front to back.
4) Put a small floor jack under the spindle so the taper is seated in the LCA and tighten it down and install the cotter pin. Access with a wrench and a rachet will be 10x better.
5) Install the UCA down over the spindle. Again, make sure the cotter pin slot goes front to rear and tighten.
Aligning the cotter pin slots seems like extra work but if you ever have to fool with it again you'll be glad you did it.
...FAFO...
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: skicker] #1726872
01/11/15 02:23 PM
01/11/15 02:23 PM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
Lovely, exactly what I wanted to do, take apart half the entire front suspension just to fix a new part. I'll buy a tap and die set next weekend and work on it. Is there an "easy" way to unseat the LCA and UCA ball joints from the spindle without using a pickle fork? And for the record, I did not hammer or file these ball joints.
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: MuuMuu101] #1726873
01/11/15 02:40 PM
01/11/15 02:40 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
The stud is bent, You can try chasing the threads but you risk cutting material from the threads on a key suspension part.
I would just purchase a new balljoint, why compromise something so important. It's 10 minutes extra work to change it out, but now is the time to do it.
Just put a centre punch in the middle of the top of the stud and give it a light tap with even a carpenters hammer, it will loosen it.
Sheldon
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: RUNCHARGER] #1726874
01/11/15 02:56 PM
01/11/15 02:56 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Sheldon
I can't see how you could for sure say it's bent from those pictures. I see a thread second from the top on the left side that looks a little dinged. He might be able to work the nut back and forth by hand to straighten that.
BTW the threads near the cotter pin are commonly chamfered in a little. No big deal. And because he took the picture pure perpendicular to the cotter pin centerline, it looks like it's necked in there.
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: autoxcuda] #1726875
01/11/15 03:14 PM
01/11/15 03:14 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I takes a lot to bend a ball joint stud and that one doesn't look bent. But the threads need fixing to where you can run the nut down by hand and then tighten it with a wrench.
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: stumpy] #1726876
01/11/15 03:18 PM
01/11/15 03:18 PM
SoCal
SoCal
I was just going to say, where is everyone seeing the bend because from that picture I don't see much of any a bend and I just took a quick look at it from under my car and it looks straight. I will agree that the threads look "smashed" by the cotter pins (not shown in the picture). The nut only went down about two full threads. I'll pull the LCA balljoint off, get a die, and try running the threads hopefully by or before next weekend.
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: MuuMuu101] #1726877
01/11/15 03:21 PM
01/11/15 03:21 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
You shouldn't need to take it off to run the die on it. Just do it were it is.
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: MuuMuu101] #1726878
01/11/15 03:40 PM
01/11/15 03:40 PM
Lake Orion, MI
Lake Orion, MI
Tie rod puller. I have a cheapo one that's kinda narrow so I may have used a pitman arm puller on the upper one. Usually comes right out.
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: MuuMuu101] #1726879
01/11/15 03:57 PM
01/11/15 03:57 PM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
If the stud is spinning in the LCA, the ball joint isn't set. Back off the torsion bar completely, jack the LCA up and the ball joint should just drop out. Then you can remove the lower ball joint, stick it in your vise, and work on it without fighting anything.
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: MuuMuu101] #1726880
01/11/15 04:00 PM
01/11/15 04:00 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I might have a die around...what thread is it?
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: OzHemi] #1726881
01/11/15 04:02 PM
01/11/15 04:02 PM
SoCal
SoCal
No idea... I don't have a thread gauge.
Re: Am I Doing Something Wrong? LCA Balljoint Issue... [Re: 6PakBee] #1726882
01/11/15 04:03 PM
01/11/15 04:03 PM
SoCal
SoCal
I already set the LCA in the ball joint to get the nut out and the Torsion bars are already backed off completely.
Page 2 of 4 1 2 3 4
