Source for Dodge D-150 Parts? #1726795
01/11/15 12:06 AM
01/11/15 12:06 AM
San Diego
Instigate Offline OP
San Diego
I'm looking for some parts and am not sure where to find them.
I need the pieces that cover the gap in between the wheel wells and the frame, as well as under the radiator. I would also like to find a place that sells the black trim that goes around the truck and those clips that hold them on. I was hit by a piece of tire tread on the freeway and it knocked a section of that black trim off! If anyone has found a good source for such things it would be appreciated. Otherwise I'll be calling junkyards. This is on an 89 D-150.
Picture of the engine compartment covers.
Re: Source for Dodge D-150 Parts? [Re: Instigate] #1726796
01/11/15 04:03 AM
01/11/15 04:03 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Try dodgeconnection.com. I used the parts they list for 78-80 on my 84 D150. They weren't exactly the same but they were close. With a little trimming here and there they fit ok.
Re: Source for Dodge D-150 Parts? [Re: TooMany62s] #1726797
01/11/15 06:57 AM
01/11/15 06:57 AM
San Diego
San Diego
Cool site. I could use a few things they sell. Thanks.
Re: Source for Dodge D-150 Parts? [Re: Instigate] #1726798
01/11/15 05:51 PM
01/11/15 05:51 PM
San Diego
San Diego
So I found a place that sells the clips for $7 a piece. I can see why most people just loose the black trim.
http://www.mopartruckparts.com/
And dodge connection has the fender seals but not the right year for me but I might do as suggested and trim the older set.
Re: Source for Dodge D-150 Parts? [Re: Instigate] #1726799
01/11/15 06:23 PM
01/11/15 06:23 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
The 78-80 parts were close on my '84. The round plastic push in clips sold at NAPA and others work fine for retention.
Re: Source for Dodge D-150 Parts? [Re: TooMany62s] #1726800
01/11/15 06:35 PM
01/11/15 06:35 PM
San Diego
San Diego
For sure. I also found a set on dixie restoration parts. The $7 clips I mentioned are to hold the black trim on the body panels all the way around.
