Page 1 of 3 1 2 3
looking for some cam opinions 360 street strip #1726737
01/10/15 11:23 PM
01/10/15 11:23 PM
ontario canada kingston
aspenrt360 Offline OP
Hey guy's I am putting together a 360 for a buddy with a 73 challenger rally it will have a 727 with a 3200 stall tci converter. our plan is to run a reasonable street gear and throw in either 3.91 or 4.10 gears for the strip depending on what we end up needing. the engine will have flat tops and I will zero deck the block, for the first couple of seasons we will run some good ported j heads with good stainless valves that I have. it will have some comp magnum roller rockers and a ld 340 intake I have a good 750 double pumper for the strip. headers will be 1-5\8 to start and as we go we may get something else. as for exhaust we will get whatever it needs to work I was kind of liking the idea of some old school cutouts, the car will be a street car but will get a fair amount of strip use probably 10 weekends or so. so what are you guy's thinking would be a good cam? it will have to be a flat tappet and I would prefer a hydraulic but I may be swayed to a solid. I am open to all idea's. just want to make a something decent that can surprise some folks. not really planning on spray or anything but it may get a small shot form time to time.
Thanks Guy's
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: looking for some cam opinions 360 street strip [Re: aspenrt360] #1726738
01/11/15 02:27 AM
01/11/15 02:27 AM
I like Comp Cams, I would probally look at and then have you decide between their XE275HL and the next bigger XE285HL grinds
Sometimes we make decisions based on today needs and then regret it later Start medium big and don't look back
Re: looking for some cam opinions 360 street strip [Re: Cab_Burge] #1726739
01/11/15 02:38 AM
01/11/15 02:38 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: looking for some cam opinions 360 street strip [Re: aspenrt360] #1726740
01/11/15 04:14 AM
01/11/15 04:14 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
I had a similar combo once in my Duster, all steel car. I used the Comp XS282S solid flat tappet. In the heat and humidity the first time out starting to tune it went 11.70
Re: looking for some cam opinions 360 street strip [Re: SpareParts] #1726741
01/11/15 08:49 AM
01/11/15 08:49 AM
Mississippi
Mr. T Offline
Mr. T  Offline
Mississippi
http://www.jegs.com/i/Mopar-Performance/312/P4120231AE/10002/-1?parentProductId=746961
I know it's old school. But, I ran this cam in my 360 for a couple of years. It had good low end torque and really pulled strong in the mid-range. I think it would work well on a street car with your converter.
Re: looking for some cam opinions 360 street strip [Re: aspenrt360] #1726742
01/11/15 02:03 PM
01/11/15 02:03 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Racer Brown ST-21.
Re: looking for some cam opinions 360 street strip [Re: qwkmopardan] #1726743
01/11/15 05:36 PM
01/11/15 05:36 PM
People's Republic of Mass.
Belvedere2 Offline
Belvedere2  Offline
Racer Brown ST-21.
Good cam but I'd like to know what he wants to run for compression first. Planning on running 93 or a race gas mix.
Re: looking for some cam opinions 360 street strip [Re: Belvedere2] #1726744
01/11/15 05:48 PM
01/11/15 05:48 PM
my plan is to get around 9.8 to one with the j heads they have had a fair amount of work done and that is where the math seems to be leading. I like the info so far, keep it coming please. I like the comp stuff myself and have run many of them but I am open to other stuff as well just hoping there is something out there I had not thought of that could be fun to try. cheers
Re: looking for some cam opinions 360 street strip [Re: aspenrt360] #1726745
01/11/15 05:52 PM
01/11/15 05:52 PM
hoping to run 94 octane street gas. that Howards cam looks kind of interesting.
Re: looking for some cam opinions 360 street strip [Re: aspenrt360] #1726746
01/11/15 05:53 PM
01/11/15 05:53 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I only use Isky stuff myself but today`s profiles have come a long way and for what you`re doing a good shelf grind will work.
Re: looking for some cam opinions 360 street strip [Re: aspenrt360] #1726747
01/11/15 05:55 PM
01/11/15 05:55 PM
I also like the comp xe I ran a milder xe 274 h years ago it was a really nice cam I have heard good stuff about the xe 275hl. anyone here run one?
Re: looking for some cam opinions 360 street strip [Re: aspenrt360] #1726748
01/11/15 06:13 PM
01/11/15 06:13 PM
Belvedere2 Offline
Belvedere2  Offline
I have 9.8:1 in my 340. I run the Racer Brown SSH-25. Bit smaller than that ST-21. I'd want to run more compression. Cam's a bit soft on the low end. It was suggested I try a Hughes cam: HEH2832Al. I'll try it out in a few months. We'll see how it works.
Re: looking for some cam opinions 360 street strip [Re: aspenrt360] #1726749
01/11/15 06:21 PM
01/11/15 06:21 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I had essentially the same combo in my dart, but ran 3.23's street and strip. Managed high 12's with a Comp XE268.
Spoke with comp in search of a more suitable cam, and they suggested the XE285HL. Unfortunately I hurt the engine before I got the chance to swap cams.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: looking for some cam opinions 360 street strip [Re: OUTLAWD] #1726750
01/11/15 06:51 PM
01/11/15 06:51 PM
looking for some real world experience as I have not had much luck when I call comp. never seem to get a switched on guy on the other end.
Re: looking for some cam opinions 360 street strip [Re: aspenrt360] #1726751
01/11/15 07:20 PM
01/11/15 07:20 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Call Isky and ask for Rod and tell em Dominic sent ya.........
Re: looking for some cam opinions 360 street strip [Re: Thumperdart] #1726752
01/11/15 07:45 PM
01/11/15 07:45 PM
I will give them a call.
Re: looking for some cam opinions 360 street strip [Re: aspenrt360] #1726753
01/11/15 09:26 PM
01/11/15 09:26 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Re: looking for some cam opinions 360 street strip [Re: Thumperdart] #1726754
01/11/15 09:35 PM
01/11/15 09:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Dom... if he drops your name.. will he get a price
break... or a higher price
Re: looking for some cam opinions 360 street strip [Re: MR_P_BODY] #1726755
01/11/15 09:37 PM
01/11/15 09:37 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Going to be TWICE as much, will come w/4 flat lobes and sandpaper to clean the rest up............
Re: looking for some cam opinions 360 street strip [Re: 70AARcuda] #1726756
01/11/15 09:40 PM
01/11/15 09:40 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Howards cams
http://www.summitracing.com/parts/hrs-710581-10/overview/make/plymouth
This would be a good cam. Depending on static compression, install it anywhere from 102-106 and run the snot out of it.
Hope the flat tops have valve reliefs.
Page 1 of 3 1 2 3
