basic360 buildup #1726676
01/10/15 10:46 PM
01/10/15 10:46 PM
ILLINOIS
V
volaredon Offline OP
V
ILLINOIS
This engine is going into my son's 89 Ramcharger when done, the truck's TBI is going into the garbage with the computer, truck will have a carb (probably one of the 2, DemonSizzler prepped TQ's I have in the attic)
3 season driver, tow vehicle, best MPG I can get "for what it is" (a 4WD "brick")
I have a '76 360 in the machine shop now. (I tried talking the kid into a carb'd magnum 360 but he bought this motor 1st)
Looking at basically a stock 0.030" overbore rebuild on the short block. Crank fine, polished up "STD". "clean up" cut on the deck if needed.
I'm putting brand new EQ Magnum heads onto this LA block. already have the heads. stock-for Magnum sized valves (not 2.02's) Bought the 318-B (LA bolt pattern) heads direct from EQ, got the fully assembled ones.
Cam; I am looking at a COMP 260H with their nitride treatment.
Pistons will be Perfect Circle, Badger etc stock replacement style.
Intake; Edebrock, not sure if we will go with a "standard" performer or an RPM... I don't remember which one of these will allow use of the factory A/C (alum. compressor)
Not wanting to replace torque converter (trans is fresh as is converter
Will break in on manifolds, but will get headers shortly after.
sound like a pretty decently matched system? I have built a few motors over the years, most pretty much "stock"
this is my son's 1st engine build I am helping him through it and showing him some of the "tricks" I have learned since then, while we are at it w/o some of the past mistakes that I have made.
I have done 1 other mag head swap/ that, on a 83 318 in a 3/4 ton pickup, that one got a stock 360-2 cam put into it at that time,(same specs as a COMP 252 at 1/2 the price) on an unrebuilt 120K mile short block, and that combo really woke that engine up to a point of some people thinking I was lying about it being "only" a 318.
A COMP 260 has a lift of 0.440" I/E with stock 1.5 rockers and .460-something with the magnum 1.6s. I want increased torque and HP but do not want to worry about piston to valve interference.
Is there a similar spec'd cam (can be a different brand) to the 260H that will accomplish what we are after?
Re: basic360 buildup [Re: volaredon] #1726677
01/10/15 11:11 PM
01/10/15 11:11 PM
ontario canada kingston
aspenrt360 Offline
aspenrt360  Offline
I did a build very much like that with some parts I had kicking around. I ran a comp 270h it runs very well good power good economy too just make sure you check valve retainer to guide clearance. I had to trim mine a bit, no big expense but if you are to tight you will be sorry. have fun it will work nice
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: basic360 buildup [Re: aspenrt360] #1726678
01/10/15 11:38 PM
01/10/15 11:38 PM
ILLINOIS
V
V
ILLINOIS
you used Magnum heads? I'll have to look into the 270H vs the 260H.
I want as LITTLE interference issues as possible valve to piston, retainer to guide etc while still waking this motor up a bit from stock. I don't see this motor ever seeing 4500 on the tach, being in a truck.
Re: basic360 buildup [Re: volaredon] #1726679
01/11/15 12:12 AM
01/11/15 12:12 AM
utica ny
meus31 Offline
meus31  Offline
utica ny
Put a better piston in it to get 9.5 to 1 or so a stock 360 piston .080 thou down doesnt help gas milage or power.
Re: basic360 buildup [Re: meus31] #1726680
01/11/15 12:22 AM
01/11/15 12:22 AM
utica ny
meus31 Offline
meus31  Offline
utica ny
My opinion is the comp xe250h would make the same power with better milage.
Re: basic360 buildup [Re: volaredon] #1726681
01/11/15 12:35 AM
01/11/15 12:35 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
When I tested cams in an rv 360, I decided a Comp Cams 268AH-10 was about as ideal a cam as you could get for a low compression 360. Very nice low RPM torque and horsepower.
You can look up the article on Mopar Muscle websites tech articles.
Budget 360 camshaft testing.
Keith
Re: basic360 buildup [Re: Dunnuck Racing] #1726682
01/11/15 01:43 AM
01/11/15 01:43 AM
ILLINOIS
V
V
ILLINOIS
thanks for the replies guys keep em coming. How much CR am I looking to pick up with the Magnum heads, vs the stock 76 pass car 360-2bbl heads that I took off this motor? (all else being equal-- assume stock piston for now) I would love to get this motor to ~9-1/4 to 9-1/2:1 CR but not much more, I want it to still run on 87. If I were driving it I might be more willing to have to run 91; but with it being my son's truck, and with premium still being half a buck more a gallon (some stations even more) than 87, I don't want a motor that "has to" have the expensive stuff.
I will look into that cam for its specs as compared to what I was gonna run. I'm "NOT" saying I have to run a COMP brand cam, either.
Re: basic360 buildup [Re: volaredon] #1726683
01/14/15 12:51 AM
01/14/15 12:51 AM
ILLINOIS
V
V
ILLINOIS
trying to bring back from about 5 pages buried;
On pistons; was looking at just stock type Badger or Silvolite.
but after suggestion above, I am thinking 9:1 flat tops with valve reliefs; that's 9:1 with stock smog heads I am thinking, with the Magnum heads (smaller chambers than the smog '76 era heads)I am thinking that it may be a a bit much for pump 87; do you guys agree?
and the machinist is telling me that if I go with anything "but" stock type replacements I'm gonna have the added expense of a balance job; It's the kid's 1st build and he's already wanting to go overboard, with me trying to tell him "hang on a a minute"
I want to teach him what I can about engine rebuilding on this one,
I want to build it up a bit while we are at it, but this is meant for daily driver duty in all but road salt season... so I don't want to overdo it. If I was building this motor for my volare I might do things a bit different than I am building it to go into a Ramcharger.
Re: basic360 buildup [Re: volaredon] #1726684
01/14/15 12:59 AM
01/14/15 12:59 AM
Northern Indiana
Northern Indiana
Check into the SpeedPro hyperutectic pistons. I'm not 100 % positive but I believe the weight is similar to stock
They have decent valve reliefs and no special ring gap needed like KB hypers.
The. Cost is right on them also.
Keith
Re: basic360 buildup [Re: Dunnuck Racing] #1726685
01/14/15 03:03 AM
01/14/15 03:03 AM
River Falls, WI
urdustd Offline
urdustd  Offline
River Falls, WI
There are two hyper pistons Speed Pro (Federal Mogul) makes. P/n 405p which has a compression height of 1.576 with a 0.070" recess and typically yields 8:1 or so compression and H116CP which has a compression height of 1.66 with 5cc valve reliefs. It will give 9.5 to 10:1 depending on head volume. This is the one I used. I have 10:1 compression and run 91 octane but can run 87 without too much issue. My engine made 397hp/435ft lbs with a mild hydraulic cam and Edelbrock heads. I didn't have to balance mine with this piston.
With factory heads it might require better fuel. Good luck with what you decide.
Re: basic360 buildup [Re: urdustd] #1726686
01/14/15 06:29 PM
01/14/15 06:29 PM
aspenrt360 Offline
aspenrt360  Offline
just got a set of the 116 cp pistons in yesterday really good bang for the buck. not an al out race piston by any means but a good economy piston that puts compression into a 360, the main thing they are missing. I just weigh one they are so close to the stock piston weight you can just go ahead and run them.
Re: basic360 buildup [Re: aspenrt360] #1726687
01/14/15 06:32 PM
01/14/15 06:32 PM
aspenrt360 Offline
aspenrt360  Offline
I got the set of pistons, pins, and clips for about $270. can't beat that price for the whole deal! they were at summit
Re: basic360 buildup [Re: aspenrt360] #1726688
01/14/15 09:32 PM
01/14/15 09:32 PM
ILLINOIS
V
V
ILLINOIS
thanks for the replies guys.
So what CR would the 116s have with EQ's "Magnum" heads? (62 or 63cc chambers) We will go with either Victor or Fel Pro "stock Replacement" Magnum engine head gaskets.
One other concept that has been getting alot of press all over is "quench" I guess more quench means more CR before better fuel is needed to prevent detonation. but I don't quite "get" how you get the quench and exactly what it is.
Re: basic360 buildup [Re: volaredon] #1726689
01/14/15 09:35 PM
01/14/15 09:35 PM
ILLINOIS
V
V
ILLINOIS
also (I think it was them) Perfect Circle used to make a cast flat top (no dish) for a 360. I am wanting to see if they still do.
Why are 360's all equipped with dished pistons where 318s aren't? They handicapped the 360 right from the factory, I wouldnt understand why theyd want that either. (though I know most 318s are "in the hole" a bit too)
Re: basic360 buildup [Re: volaredon] #1726690
01/15/15 02:50 PM
01/15/15 02:50 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Depends on your deck height. That piston at "0" deck, with a .041 gasket and 63cc chamber calculates to 10.7:1
.050 in hole, calculates to 9.5:1
Re: basic360 buildup [Re: volaredon] #1726691
01/15/15 02:57 PM
01/15/15 02:57 PM
cudadoug Offline
cudadoug  Offline
Yes, you can still get replacement, dished pistons for the 360 through any auto parts house.
Here's another option that's C H E A P. They're an ugly pistons but have proven to be rock solid relaibale in a build such as yours. I even know of one set in a motor that's gone high 11's now for going 4 years. I know of another set in a pulling truck AND had 40K+ street miles on it. Motor came down last year for a freshen...pistons/rings were A-Okay!
http://www.summitracing.com/parts/slp-h405cp30/overview/make/chrysler
Re: basic360 buildup [Re: cudadoug] #1726692
01/15/15 05:18 PM
01/15/15 05:18 PM
aspenrt360 Offline
aspenrt360  Offline
I put a set of those 405's in a truck motor they work well too. a bit less comp though depends on what you want to build. and if you want to do some bolt on upgrades down the road.
Re: basic360 buildup [Re: cudadoug] #1726693
01/15/15 10:08 PM
01/15/15 10:08 PM
ILLINOIS
V
V
ILLINOIS
Yeah I know OEM style stock "dished" pistons are available everywhere "a dime a dozen", in the post where I asked that I was looking for a cast flat top (NOT dished)
Those ones you link to at summit are the ones I am looking into getting. Would I need a balance job to go with them vs the stock typed dished POS'?
Already have the Magnum heads on hand they are a definite to go onto this engine, looking for around 9:1 to 9-1/4 to 1 probably at most.
Definitely wanting a boost from the OEM sub-8:1
NOT wanting "cheap" for the sake of cheap nor bragging rights for "most expensive" 360 towing/4X4 motor but bottom line is BANG FOR THE BUCK...
Block at machine shop it has not yet bored as of 2 days ago/ was told to hold off on buying to be sure it'll clean up there; I wanted only 0.020 over but machinists claim 0.020 "harder to find" and pretty much insist on going 030 if any at all... so I have been shopping 30-over
Re: basic360 buildup [Re: volaredon] #1726694
01/15/15 10:45 PM
01/15/15 10:45 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I am pretty sure the 380 hp 360 magnum crate motor is 9-9.5 comp. I do not know what brand they are but you could look into that.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: basic360 buildup [Re: D-50] #1726695
01/15/15 11:56 PM
01/15/15 11:56 PM
ILLINOIS
V
V
ILLINOIS
that's exactly where I'd like this motor to wind up when all is said and done. no more though due to not wanting to be stuck running Premium.
