Carb shopping #1726628
01/10/15 08:56 PM
01/10/15 08:56 PM
pacific northwest
Stroker Scamp Offline OP
pacific northwest
340, larger than stock cam (no specs), RPM Air gap, stock bottom end, headers
Looking for a Holley 750 double pumper
I think I have it narrowed down to the 4150 Street HP,
anyone run this carb on a mostly street driven car??
Opinions
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Carb shopping [Re: Stroker Scamp] #1726629
01/10/15 09:17 PM
01/10/15 09:17 PM
johnmilner Offline
johnmilner  Offline
650 double pumper.
Re: Carb shopping [Re: johnmilner] #1726630
01/10/15 10:04 PM
01/10/15 10:04 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
IMO: I agree with above. Sounds like a street car, I'd go with a 650 street HP. The 750 might ultimately give a better ET at the drag strip with open headers, but the 650 will be better at everything else on 340 cubes. I think it would offer better throttle response and a crisper feel.
Re: Carb shopping [Re: Stroker Scamp] #1726631
01/10/15 10:10 PM
01/10/15 10:10 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Auto with some converter or 4 speed?
If you can tune a carb, go with the 750.
I run my 340's with nothing smaller than a 750.
Re: Carb shopping [Re: Stroker Scamp] #1726632
01/10/15 10:13 PM
01/10/15 10:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its more about your conv and rear gear as to what carb
you need to use... a 750 was on a stock 340
Re: Carb shopping [Re: StealthWedge67] #1726633
01/10/15 10:46 PM
01/10/15 10:46 PM
Denison,Ia.
Cuda367 Offline
Cuda367  Offline
Denison,Ia.
You won't listen but 750 street demon. More throtle reponse than you will know what to do with and the air to feed it upstairs
Re: Carb shopping [Re: Cuda367] #1726634
01/10/15 11:22 PM
01/10/15 11:22 PM
pacific northwest
pacific northwest
automatic, gears are 323,
eventually I may stroke it
Re: Carb shopping [Re: Stroker Scamp] #1726635
01/11/15 12:57 AM
01/11/15 12:57 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Stock stroke 340/auto (unknown conv)/3:23 gears= vacuum secondary with tunable circuits (jets/air bleeds). 650-700cfm
Re: Carb shopping [Re: MR_P_BODY] #1726636
01/13/15 09:25 PM
01/13/15 09:25 PM
Earth
Rob C Offline
Rob C  Offline
Earth
When was a 750 stock on a 340?
The square ore Carters were 600/630
Both size TQ's came on the 340 IIRC. You call them what for cfm size?
Normally I hear them called 800/850.
Re: Carb shopping [Re: Rob C] #1726637
01/13/15 09:31 PM
01/13/15 09:31 PM
In a house near you
Street Monkies Offline
In a house near you
They had over 1000 cfm on the T/A's
Re: Carb shopping [Re: Street Monkies] #1726638
01/13/15 09:39 PM
01/13/15 09:39 PM
Earth
Rob C Offline
Rob C  Offline
Earth
Yes, the race TQ. I own one. Haven't had the chance to run it yet.
I wonder about the true cfm dry vs. wet.
Sorry, fat fingers and home distractions left this post...... Unfinished.
And yes, as stated below, the 6pack induction was a street strip champ.
See below for cfm ratings between 4 & 2 bbl. carbs.
Re: Carb shopping [Re: Street Monkies] #1726639
01/13/15 09:39 PM
01/13/15 09:39 PM
dogdays Offline
dogdays  Offline
Not that again! Two-barrel carbs are rated differently, you need to divide the two barrel rating by the square root of two (1.4142) to convert to a four barrel reading. For 1350 two barrel cfm that equates to 955 four barrel cfm. BUT, the carb setup opened the end carbs only as much as the engine needed so I don't think any stock 340 ever used all of the 6-pack capacity.
R.
Re: Carb shopping [Re: dogdays] #1726640
01/13/15 09:58 PM
01/13/15 09:58 PM
In a house near you
In a house near you
Right but if you look at it this way. A motor will only draw in so much cfm of the carburetor. It doesn't matter what carb, style, or model if motor only can take in 500 cfm and you use a 650 then what? Is it to big now? You can run any carb you want but if it's a street set up then who gives a turkey about size really lol. As long as motor is getting fuel and is working like it's supposed to.
Re: Carb shopping [Re: Cuda367] #1726641
01/13/15 09:59 PM
01/13/15 09:59 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
You won't listen but 750 street demon. More throttle response than you will know what to do with and the air to feed it upstairs
(except for the 750 part) The Double Pumpers are awful rich when used on a street car unless lots of time is spent tuning them. They are good carbs, but are more geared toward acceleration competitions than cruising.
The Demons start much more street friendly on their tune. If adjustments are needed, they are fewer and typically take fewer steps.
And besides the tune, the Demons also have some street friendly design features that the Holleys don't. Which will also help throttle response and driveability.
If you are choosing for the strip, then I would probably choose the 750 DP. But for the street, the 625 Street Demon should get the nod.
Master, again and still
Re: Carb shopping [Re: Stroker Scamp] #1726642
01/16/15 12:40 AM
01/16/15 12:40 AM
Maryland
Mopar Bob Offline
Mopar Bob  Offline
Maryland
Street car, mild 340. You might consider a 650 vacuum secondary. Is it an automatic? I didn't see that noted.
Re: Carb shopping [Re: Mopar Bob] #1726643
01/16/15 03:28 AM
01/16/15 03:28 AM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
I'd love to own the competition series TQ (1000 cfm), but those are like hen's teeth
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: Carb shopping [Re: VincentVega] #1726644
01/16/15 05:30 AM
01/16/15 05:30 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I used this 750 Holley choke less race carb with good results in my 400hp 360.
Re: Carb shopping [Re: ademon] #1726645
01/16/15 05:37 AM
01/16/15 05:37 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
But this mechanical 6 pack setup replaced the 4bbl and single plane. The engine seems slightly stronger with the 6 pack even with the 1,150cfms and no jetting!
Re: Carb shopping [Re: ademon] #1726646
01/16/15 05:38 AM
01/16/15 05:38 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Re: Carb shopping [Re: ademon] #1726647
01/16/15 05:42 AM
01/16/15 05:42 AM
RobX4406 Offline
RobX4406  Offline
~813 cfm in 4 bbl terms.
