Agree with above. Make yourself a "truth table"
Find out (I think they do) use integrated brake and tail lamps
Here is what you will have
1...Because 1 wire goes to the pilot lamp, this "indicates" a 3 pin flasher.
2...You would have the following INputs
flasher power going in
flasher pilot lamp going in
brake switch power going in
3...You would have the following OUTputs
left front turn
right front turn
left rear turn / brake
Therefore you should have the following:
"Whatever" is the brake like wire should be continuous to the two (left and right) rear turn/ brake outputs with the switch CENTERED
So right away you can "group" those three
Next, turn the switch to "left" and take the three wires in the "group" and find out which OTHER TWO wires ONE of the three hooks to, IE
in "left" of course the "flasher in" will be hooked to left front and left rear
Separately, the brake power "in" will be hooked to the RIGHT rear lamp
How to determine? At first, you can leave the switch centered, but you won't really know which is brake, which is right, and which is left. Easy. Three wires. All continuous with switch centered. With switch left, two of the three will be continuous, and with switch right, the third will be continous with one of the first two. The wire that's continous in all three cases is the BRAKE SWITCH.
So now you have id'd the brake switch, and left / right rear, and you already know the pilot lamp, only 3 left
Take your left and right rear, and cycle the switch left right, determine which of the remaining wires are continuous with one in left, one in right. This is your flasher.
Now take this flasher wire and check the TWO remaining wires for continuity, left, and right. These are your left/ right front.
You should now have TWO hooked together, with the switch in "right" that is the left rear brake "out" and the brake switch "in"
If the colors are bad figure some way of marking them, either colored tape (you can buy at Lowes, electrical stores etc) or even numbered mask. tape.
This takes longer to explain than to "do" LOL
