Why no buzz here on this neat solution? #1725867
01/09/15 05:10 PM
01/09/15 05:10 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
Re: Why no buzz here on this neat solution? [Re: jcc] #1725868
01/09/15 05:53 PM
01/09/15 05:53 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
I'm anxiously awaiting it's release. I called Holley in December for more information - the guy I spoke with didn't have much info.
I also tried to find out what the ARCA spec fuel pump is. The Ilmor efi 396 spec motor puts out 700+ hp. The guy at Ilmor gave me a specific contact at Holley, but I have yet to get him on the phone.
Things I want to know:
-what is the ARCA spec EFI pump
-will the hydramat cause any vacuum at the inlet of an EFI pump? (most efi pumps list 'gravity fed' as a requirement)
I need to make some fuel system changes. But I'm not changing anything until the hydramat comes out.
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: Why no buzz here on this neat solution? [Re: Uhcoog1] #1725869
01/09/15 06:44 PM
01/09/15 06:44 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not real sure it's a "neat" solution.
I can see it messing up sending units, kinda important on a street car. Waiting to see if and/or how it's addressed.
Waiting to see how "neat" the price is. I suspected it'll be really boffo.
Again, refer to my link in the other post you referenced.
Don't be the exception.
Re: Why no buzz here on this neat solution? [Re: jcc] #1725870
01/09/15 07:17 PM
01/09/15 07:17 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
That's a cool piece and glad that it will fit inside an ATL fuel cell
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Why no buzz here on this neat solution? [Re: RylisPro] #1725871
01/09/15 10:26 PM
01/09/15 10:26 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
I'd be curious how much this costs. I think a lot of us would be adequately served by the Aeromotive Phantom system. Looking at the one of those I have here, I can't see how you'd have a fuel starvation problem so long as you had over a gallon of fuel in the tank (who would run their car hard with less than that anyway?). 340 lph should be enough for all of us as well.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Why no buzz here on this neat solution? [Re: goldduster318] #1725872
01/09/15 10:32 PM
01/09/15 10:32 PM
Santa Fe Springs, CA
Dan@Hotchkis Offline
<raises hand>
SCCA National Tour event. We got busted for weight at impound as well, buy less than what a gallon of gas weighs too
Re: Why no buzz here on this neat solution? [Re: RylisPro] #1725873
01/09/15 10:32 PM
01/09/15 10:32 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
Looks to me like it would fit a stock tank, if you had an opening to insert it, for the stock appearing crowd.
I just can't see the cost being outrageous, and if they do gouge, it will only stymie a nice product.
This will halt any of my fuel tank projects until its out on the market.
I would think this thing will work with EFI pumps in low lift, especially since the will never see any air.
Was this at PRI and did anybody put eyeballs on it?
Re: Why no buzz here on this neat solution? [Re: jcc] #1725874
01/09/15 10:39 PM
01/09/15 10:39 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
the site does say it's not compatible with methanol, but no mention of ethanol. no matter what, it's some pretty cool stuff. I bet they price it where the cost will be slightly cheaper than an in tank.
Re: Why no buzz here on this neat solution? [Re: ntstlgl1970] #1725875
01/09/15 10:56 PM
01/09/15 10:56 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
My first guess would be methanol will be a problem as expected, but I really wonder if its a surface tension issue, which is what the design depends on, if I understand the concept correctly.
Re: Why no buzz here on this neat solution? [Re: jcc] #1725876
01/10/15 01:03 AM
01/10/15 01:03 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
A methanol compatible version is coming, if you read the flyer.
Methanol is very corrosive, that is probably the issue.
Re: Why no buzz here on this neat solution? [Re: jcc] #1725877
02/23/15 04:09 PM
02/23/15 04:09 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Price is out, out there is stupid land too.
Re: Why no buzz here on this neat solution? [Re: Supercuda] #1725878
02/23/15 05:00 PM
02/23/15 05:00 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
If it was HALF this price I would still be on the fence...
https://www.holley.com/products/fuel_systems/hydramat/parts/12-924
Mopar to the bone!!!
Re: Why no buzz here on this neat solution? [Re: 72Swinger] #1725879
02/23/15 05:37 PM
02/23/15 05:37 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I can get an EFI tank, pump and sender for my 65 Cuda for less.
http://www.tanksinc.com/index.cfm/page/p...prod/prd479.htm
Re: Why no buzz here on this neat solution? [Re: Supercuda] #1725880
02/23/15 06:28 PM
02/23/15 06:28 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Your post is the first I've seen of this offering from Tanks. I just called Tanks, and they said late April at the earliest for the 70-76 duster tanks (others are coming sooner). They're stamped overseas, and they do have a front to back baffle (5" running full width), and a 4.3 quart tray under the pump (with holes to allow fuel to flow in).
Count me in. I'll be buying and installing one as soon as I can get my hands on it.
Re: Why no buzz here on this neat solution? [Re: Uhcoog1] #1725881
02/23/15 06:51 PM
02/23/15 06:51 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I have been pondering my options in this regard since the 90's when I converted my 87 Diplomat to Holley Projection.
An unbaffled tank feeding EFI directly is a bad thing. I ended up with a small capacity surge tank fed by the mechanical pump with it feeding the EFI pump and the over flow going back to the main tank via the surge tank. Yes, the surge tank had an overflow that went back to the main tank. I did that to eliminate any air in the surge tank whatsoever. It worked, which is more than I can say about the Projection setup.
Re: Why no buzz here on this neat solution? [Re: Supercuda] #1725882
02/23/15 10:30 PM
02/23/15 10:30 PM
South Bend
John Brown Online content
John Brown  Online Content
South Bend
If you ever had any experience behind the counter at a speed shop, you'd realize that nothing shown in magazine articles is in production or the pipeline or will be for at least a year from when the first article comes out. The manufacturers let the articles hit the newsstand to judge what interest they can expect. I always hated when customers wanted me to to call the factory to see if they could get that latest shiny new item.
Re: Why no buzz here on this neat solution? [Re: John Brown] #1725883
02/23/15 11:37 PM
02/23/15 11:37 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Oh I ain't spending $700 or a large fraction thereof for the solution. Regardless of if it's in stock or not.
I have a much cheaper solution, it's been posted a few times but one more time
http://autoperformanceengineering.com/html/pickups.html
Re: Why no buzz here on this neat solution? [Re: Supercuda] #1725884
02/24/15 12:17 AM
02/24/15 12:17 AM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
these are the same pickups used in the vaporworx (Rick's stainless) system discussed in other threads. neat stuff
Re: Why no buzz here on this neat solution? [Re: 72Swinger] #1725885
02/24/15 12:58 AM
02/24/15 12:58 AM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
That's nuts! I'm shocked at that price! I hope ( not holding my breath) this is just a ARCA "tax" on a spec built part?
Re: Why no buzz here on this neat solution? [Re: brads70] #1725886
02/24/15 11:04 AM
02/24/15 11:04 AM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
Aeromotive has a tank sock that is brillian to efi pump retrofits. Its been out for at least a few months.
