Re: Torqueflight HELP!!!!!!!!!!!
[Re: dOoC]
#172579
12/21/08 11:18 PM
12/21/08 11:18 PM
Posts: 316 Coolville, Ohio
Lew
Coolville, Ohio
Does this happen only after sitting a long time ? ... like over-nite or longer ?
As was suggested earlier ...a pressure check is in order.
It can work fine after sitting for 6 weeks, but I can stop at the gas station and it will not work after sitting for 3 minutes. It has also worked and then not worked with the engine never being shut off. It is never consistent. Ususally works fine, but every now and then without warning, I'm stuck.
[Re: racincuda]
#172581
12/22/08 06:53 AM
12/22/08 06:53 AM
Lew
Coolville, Ohio
Well this is just a guess but it may be because of too much heat in th trans. I kno it had caused mine to stick in 1 gear for way too long, like 1 - 2 minutes after refiring and driving down th road. Soo is your cooling system keeping everything cool, Eng & trans ? Do you hav a trans temp gauge ?
I don't have a trans temp gauge, but it has a trans cooler and it it has done it a few times when it was first started and cold. However, it has also dont it when it is warmed up.
[Re: 440Jim]
#172585
12/22/08 11:26 AM
12/22/08 11:26 AM
Posts: 614 Michigan
Get-X
Sounds like the convertor is draining back. Might be a mismatched pump. Try parking the car in neutral and see if it still happens.
'65 Belvedere '68 GTX '57 Dodge pickup
[Re: Lew]
#172586
12/22/08 01:48 PM
12/22/08 01:48 PM
Posts: 916 MB,CAN
PC-CHARGER
MB,CAN
In my mind, it has to be something common to reverse and drive so that would eliminate the clutch packs and bands or sprag simply becasue reverse uses one band and clutch while Drive use another clutch and sprag. I don't think there's anything in the converter that would cause this type of intermittent problem unless as was stated already, it's draining back and not filling for some reason. But, one would think this would be more prevalent after sitting for awhile. I'd suggest trying a different valve body and failing that, it likely will have to come apart. Maybe the drive lugs on the pump are broken and they jam occasionally enough to drive the pump and then break free again. A stretch but my guess it is in the pump circuit somewhere. One other thing comes to mind. The rooster comb and lever that moves the manual valve in the valve body is known to break loose from it's serrations. This would cause this problem and would not be noticeable until the pan was dropped.
