Torqueflight HELP!!!!!!!!!!! #172574
12/21/08 08:02 PM
12/21/08 08:02 PM
Coolville, Ohio
Lew Offline OP
Lew  Offline OP
Coolville, Ohio
Intermittently, 727 will not move in forward or reverse gear. Filter has been replaced, all bands have been properly adjusted to specs listed in Chilton manual. Car shifts firmly when operational in all gears. Trans has deep pan with filter extension. Never know when it is not going to move. Only happens about once in a while. Stock floor shift. Car is 1969 'Cuda. Does this sound like a problem I can get to just taking the pan off? Or does this sound like removal of H-pipe, trans, and a rebuild? Let me know if you need anymore info...
Re: Torqueflight HELP!!!!!!!!!!! [Re: Lew] #172575
12/21/08 08:23 PM
12/21/08 08:23 PM
Keysville, VA
drag440 Offline
mopar addict
drag440  Offline
mopar addict
Keysville, VA
Sounds like a valvebody problem? I would take the valvebody out and totaly disassemble it, clean and blow it out then reinstall and try it.
Re: Torqueflight HELP!!!!!!!!!!! [Re: Lew] #172576
12/21/08 09:08 PM
12/21/08 09:08 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
maybe the front pump..
Re: Torqueflight HELP!!!!!!!!!!! [Re: 70blackfish] #172577
12/21/08 09:14 PM
12/21/08 09:14 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I would start by checking your line pressure and servo pressure, to me if it has good line pressure then the pump is probably good and then I would suspect a valve body problem.
Re: Torqueflight HELP!!!!!!!!!!! [Re: Lew] #172578
12/21/08 09:45 PM
12/21/08 09:45 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Does this happen only after sitting a long time ? ... like over-nite or longer ?
As was suggested earlier ...a pressure check is in order.
Re: Torqueflight HELP!!!!!!!!!!! [Re: dOc !] #172579
12/21/08 11:18 PM
12/21/08 11:18 PM
Coolville, Ohio
Lew Offline OP
Lew  Offline OP
Coolville, Ohio
It can work fine after sitting for 6 weeks, but I can stop at the gas station and it will not work after sitting for 3 minutes. It has also worked and then not worked with the engine never being shut off. It is never consistent. Ususally works fine, but every now and then without warning, I'm stuck.
Re: Torqueflight HELP!!!!!!!!!!! [Re: Lew] #172580
12/21/08 11:34 PM
12/21/08 11:34 PM
Kansas
racincuda Offline
racincuda  Offline
Kansas
Well this is just a guess but it may be because of too much heat in th trans.
I kno it had caused mine to stick in 1 gear for way too long, like 1 - 2 minutes after refiring and driving down th road.
Soo is your cooling system keeping everything cool, Eng & trans ?
Do you hav a trans temp gauge ?
Re: Torqueflight HELP!!!!!!!!!!! [Re: racincuda] #172581
12/22/08 06:53 AM
12/22/08 06:53 AM
Coolville, Ohio
Lew Offline OP
Lew  Offline OP
Coolville, Ohio
I don't have a trans temp gauge, but it has a trans cooler and it it has done it a few times when it was first started and cold. However, it has also dont it when it is warmed up.
Re: Torqueflight HELP!!!!!!!!!!! [Re: Lew] #172582
12/22/08 10:28 AM
12/22/08 10:28 AM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
How do you get the car to move again once it has stopped going into gear?
Re: Torqueflight HELP!!!!!!!!!!! [Re: PC-CHARGER] #172583
12/22/08 10:58 AM
12/22/08 10:58 AM
Coolville, Ohio
Lew Offline OP
Lew  Offline OP
Coolville, Ohio
Not sure. After a while it just goes. Sometimes 10 seconds...sometimes 5 minutes...sometimes it just never goes...then when you start it the next day it runs like a champ. Last night when I posted, it would not move after 15 min of screwing with it. Woke up this morning, hit key, fell right into gear, took for a test drive where it shifted great and chirped 2nd gear. Wasn't a heating issue because it was also cold last night and would not move. I usually let it idle in neutral before it goes into gear, and it has plenty of fluid. Just never know when (or where) it will happen.
Re: Torqueflight HELP!!!!!!!!!!! [Re: Lew] #172584
12/22/08 11:17 AM
12/22/08 11:17 AM
NC
440Jim Offline
440Jim  Offline
NC
Intermittant problems (in anything) are usually the hardest to diagnois. Besides disassembly and cleaning the valve body, you did the other easier stuff. After that a complete rebuild to eliminate a funky seal, ring, etc.
Re: Torqueflight HELP!!!!!!!!!!! [Re: 440Jim] #172585
12/22/08 11:26 AM
12/22/08 11:26 AM
Get-X Offline
Get-X  Offline
Sounds like the convertor is draining back. Might be a mismatched pump. Try parking the car in neutral and see if it still happens.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: Torqueflight HELP!!!!!!!!!!! [Re: Lew] #172586
12/22/08 01:48 PM
12/22/08 01:48 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
In my mind, it has to be something common to reverse and drive so that would eliminate the clutch packs and bands or sprag simply becasue reverse uses one band and clutch while Drive use another clutch and sprag. I don't think there's anything in the converter that would cause this type of intermittent problem unless as was stated already, it's draining back and not filling for some reason. But, one would think this would be more prevalent after sitting for awhile. I'd suggest trying a different valve body and failing that, it likely will have to come apart. Maybe the drive lugs on the pump are broken and they jam occasionally enough to drive the pump and then break free again. A stretch but my guess it is in the pump circuit somewhere. One other thing comes to mind. The rooster comb and lever that moves the manual valve in the valve body is known to break loose from it's serrations. This would cause this problem and would not be noticeable until the pan was dropped.
Re: Torqueflight HELP!!!!!!!!!!! [Re: PC-CHARGER] #172587
12/22/08 02:06 PM
12/22/08 02:06 PM
LEBANON;PA
daron Offline
daron  Offline
LEBANON;PA
blow out the passage holes in the case and check the low reverse valve for small burr
