Any Indy Maxx 655 info #1725256
01/09/15 01:11 AM
01/09/15 01:11 AM
tn
robnbird Offline OP
robnbird  Offline OP
tn
If you have or know about the pistons camshaft and rods for a indy 655 with 600-13 heads. I would like to know about this engine .. I have just acquired one and need a few parts for it , like 2 piston 2 rods a camshaft and bearings .. So if you can give me any info please let me know .. Thanks
Re: Any Indy Maxx 655 info [Re: robnbird] #1725257
01/09/15 01:38 AM
01/09/15 01:38 AM
CLARKSVILLE,TN.
DAYTONA540 Offline
DAYTONA540  Offline
CLARKSVILLE,TN.
I'll try,
pistons- P/N 440-P1-1062, C/H 1.250, Bore 4.563
Price $1400.00
Rods- P/N ALL-C4-714, 6.950 GRP 5301 PRO SERIES
Price $1215.00
Those numbers and prices are from Indy I'm sure you can purchase singles,but its indy who knows.
On the cam I have one being sent to me this week
check back this time next I might be able to help you. Hope this helps.
Re: Any Indy Maxx 655 info [Re: DAYTONA540] #1725258
01/09/15 03:21 AM
01/09/15 03:21 AM
tn
robnbird Offline OP
robnbird  Offline OP
tn
thanks for the info . is this the same as a chevy rod ? and what about a h beam steel rod ? where is the cam coming from . I also need the cam bearings.
Re: Any Indy Maxx 655 info [Re: robnbird] #1725259
01/09/15 11:19 AM
01/09/15 11:19 AM
CLARKSVILLE,TN.
DAYTONA540 Offline
DAYTONA540  Offline
CLARKSVILLE,TN.
The rods for the 655 are 2.200 rod journal.Is your block 55mm roller bearings? The cam I have coming has std type bearings and was used on a 622 Indy block with 600-13 heads. I should have it first of next week.
Re: Any Indy Maxx 655 info [Re: DAYTONA540] #1725260
01/09/15 01:47 PM
01/09/15 01:47 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
why did you replace the cam ?
Re: Any Indy Maxx 655 info [Re: robnbird] #1725261
01/09/15 06:16 PM
01/09/15 06:16 PM
CLARKSVILLE,TN.
DAYTONA540 Offline
DAYTONA540  Offline
CLARKSVILLE,TN.
I didn't replace anything.I bought the cam from a guy that was parting our a 622. Best is building him a new 622 and would not use any used valve train parts. His Indy block had a previous repair that did not work out and he started over fresh.You still have not said what cam bearings you have in your block. If they are 55 mm then this cam makes no diff.
Re: Any Indy Maxx 655 info [Re: DAYTONA540] #1725262
01/09/15 07:00 PM
01/09/15 07:00 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
it doesn't have any so Im not sure .. does he have any rockers?
Re: Any Indy Maxx 655 info [Re: robnbird] #1725263
01/09/15 09:15 PM
01/09/15 09:15 PM
nj glouster county usa
daytonaman Offline
daytonaman  Offline
I have miscellaneous parts needed for that engine, contact me to discuss what you may need, I just might have what you are looking for.
