Who sells the correct heat riser kits for a 340? #1725066
01/08/15 07:43 PM
01/08/15 07:43 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Anyone purchase a heat riser kit for a 70 340 exhaust manifold? If so, where did you purchase the kit? I believe the exhaust manifolds were the same for 68-70 340 model years.
Re: Who sells the correct heat riser kits for a 340? [Re: vinnyd76] #1725067
01/09/15 05:27 AM
01/09/15 05:27 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
AFAIK, NOS is all that's available, but there always seems to be a few out there. For now.
If the car is to be a daily driver in MI during winter, I guess maybe you need one that works. But if you are only going to drive the car in above freezing temperatures, you can get by without one, by using only the exterior parts if you want it to look original. The spring and thermostat have a relatively short life span in my experience.
If you find a kit, be certain it is for 340 and study the drawing in the factory service manual to be sure it has all the needed parts...
