Opinion on Cam choice?
#1724997
01/08/15 06:05 PM
01/08/15 06:05 PM
Posts: 1,250 North Carolina
469runner
North Carolina
I am putting together a 2nd generation HEMI and would like an opinion on the cam I have. This is a 484 ci, ported Stage V heads from Tim Banning, stock 2 plane intake and stock carbs. TTI headers. Comp Cams: Solid Roller, Duration @ .050 236/243, Lift, .603/.552 at valve. Lobe centerline, 113 degrees.
I'm not too familiar with solid rollers. Will this be streetable? Will it have a decent idle? Enough vacuum for power brakes? I got this cam and lifter set with a bunch of other parts purchased. Probably over $1,000 bought new, so would hate to waste it.
Re: Opinion on Cam choice?
[Re: 469runner]
#1724998
01/08/15 06:23 PM
01/08/15 06:23 PM
Posts: 5,166 CT
GTX MATT
CT
That cam will be very streetable with 484 cubes, it should have a little gallop to the idle but nothing crazy.
