Pins stuck in new pistons... #1724949
01/08/15 03:44 PM
01/08/15 03:44 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
I have this set of new Speed Pro 440 forged pistons that has been sitting in the box on a shelf for several years. The pins are all stuck in the pistons. There is no rust on the pins. I sprayed the pins with wd-40 about a week ago and yesterday wrapped one with a plastic mallet a couple of times, but it did not budge. Any tips??
I going to sell them, but I want to make sure there is no problems first.
Re: Pins stuck in new pistons... [Re: rarefish] #1724950
01/08/15 04:00 PM
01/08/15 04:00 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
use something like pb blaster, or kroil. soak them overnight. other thing to do, is warm them up in an oven. try to push the pin out, while it's still hot. use a press, not a hammer.
Re: Pins stuck in new pistons... [Re: rarefish] #1724951
01/08/15 04:01 PM
01/08/15 04:01 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
So you don't risk damage to the pin or pistons check your local machine shop to see if they have a sunnen pin press. Do not try to do it with a regular hydraulic press you cannot square up the piston like you can with the right tooling of a sunnen press.
MLR426
Re: Pins stuck in new pistons... [Re: rarefish] #1724952
01/08/15 04:30 PM
01/08/15 04:30 PM
Take a hair dryer or heat gun and warm up the pin boss area and push them out, you may have some corrosion If so scotch brite and WD 40 will help clean them up, make sure to use a rust preventive on them when you reassemble them, not WD40 WD40 = Water Displacement formula #40, it evaporates and does not prevent rust is what I think
Re: Pins stuck in new pistons... [Re: Golden-Arm] #1724953
01/08/15 06:37 PM
01/08/15 06:37 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
I gave one a shot of Kroil and I will let it sit for a while to see if it helps.
Re: Pins stuck in new pistons... [Re: rarefish] #1724954
01/08/15 06:51 PM
01/08/15 06:51 PM
fury4speed Offline
fury4speed  Offline
+1 with Kroil or maybe a hair dryer or oven.
Re: Pins stuck in new pistons... [Re: fury4speed] #1724955
01/08/15 06:56 PM
01/08/15 06:56 PM
Heat!!!! Set them on top of the Kerosun for a minute they will come out--
Re: Pins stuck in new pistons... [Re: ] #1724956
01/08/15 08:35 PM
01/08/15 08:35 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
The piston should heat up and expand faster than the pin.
Re: Pins stuck in new pistons... [Re: TJP] #1724957
01/08/15 09:58 PM
01/08/15 09:58 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
Well I put one of them in the oven at 250 deg for about 15 minutes and was able to push the pin out with gloves on. No rust found. Just a tight fit.
Thanks everyone for the help.
Re: Pins stuck in new pistons... [Re: rarefish] #1724958
01/08/15 09:59 PM
01/08/15 09:59 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
run them under hot water the pins will loosen and slide out. keep it simple
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: Pins stuck in new pistons... [Re: yella71] #1724959
01/08/15 11:20 PM
01/08/15 11:20 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
Kriegers .. $1.50 lb ...
Re: Pins stuck in new pistons... [Re: sogtx] #1724960
01/09/15 01:20 AM
01/09/15 01:20 AM
Kreigers,Vas es los(what is that stuff )
Re: Pins stuck in new pistons... [Re: Cab_Burge] #1724961
01/09/15 01:59 PM
01/09/15 01:59 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
Now the wrist pin hole needs to be resized to
fit the pin properly, failure to do this will lead to unpleasant results.
Re: Pins stuck in new pistons... [Re: MO_PA] #1724962
01/09/15 03:17 PM
01/09/15 03:17 PM
dogdays Offline
dogdays  Offline
Maybe.....What makes an engine produce power? Heat in the combustion chamber expanding gases pushing the piston down.
So it should be a given that nearly as soon as the engine starts running at all, the pistons warm up. By the nature of the two metals involved, the aluminum piston pin hole expands twice as fast as the steel pin.
I've seen this happen many times, take the piston out of the box and the pin appears to be stuck. At the same time I've never known an engine rebuilder doing a commercial type job to stop at this point and resize the pin bore. So it must not be a huge problem, at least for the average rebuilt engine.
IMHO it's a "nice to have" rather than a "must do".
R.
Re: Pins stuck in new pistons... [Re: MO_PA] #1724963
01/09/15 03:19 PM
01/09/15 03:19 PM
If I'm using new pistons and wrist pins with press fit rods I have the pistons and pins pin fitted to make sure that the wrist pin to piston clearances are at least .0008 to .0010, if there going in a rod that has wrist pin retainers where the wrist pin floats in tthe rod and piston I have the rods done also to the same specs. Race motors like a tiny bit looser, the piston alloy also plays into how much to use and room temperature can play into reading the clearances also, depending on which gauges your using
Re: Pins stuck in new pistons... [Re: Cab_Burge] #1724964
01/10/15 09:42 AM
01/10/15 09:42 AM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
Sorry, Jon knows -- Its a local scrapyard in Rochester ...
... Sorry its not the secret lubricant ..
Re: Pins stuck in new pistons... [Re: sogtx] #1724965
01/10/15 01:05 PM
01/10/15 01:05 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I think it's "vas ist das" what is that,
"vas ist los" is what is wrong, loosely
Joe
Re: Pins stuck in new pistons... [Re: jlatessa] #1724966
01/10/15 05:05 PM
01/10/15 05:05 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Joe
Living around a bunch of Germans (and marrying one), around here vas ist los is commonly used as 'what's up?'
Re: Pins stuck in new pistons... [Re: 6PakBee] #1724967
01/10/15 06:32 PM
01/10/15 06:32 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I said loosely...it is used that way too
Joe
