Re: Pins stuck in new pistons...
[Re: Golden-Arm]
#1724953
01/08/15 06:37 PM
01/08/15 06:37 PM
Posts: 2,252 New York
rarefish
New York
use something like pb blaster, or kroil. soak them overnight. other thing to do, is warm them up in an oven. try to push the pin out, while it's still hot. use a press, not a hammer.
I gave one a shot of Kroil and I will let it sit for a while to see if it helps.
[Re: fury4speed]
#1724955
01/08/15 06:56 PM
01/08/15 06:56 PM
Heat!!!! Set them on top of the Kerosun for a minute they will come out--
[Re: ]
#1724956
01/08/15 08:35 PM
01/08/15 08:35 PM
Posts: 15,377 Omaha Ne
TJP
Omaha Ne
The piston should heat up and expand faster than the pin.
[Re: rarefish]
#1724958
01/08/15 09:59 PM
01/08/15 09:59 PM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
run them under hot water the pins will loosen and slide out. keep it simple
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
[Re: Cab_Burge]
#1724964
01/10/15 09:42 AM
01/10/15 09:42 AM
Posts: 5,180 upstate western ny
sogtx
upstate western ny
Kriegers .. $1.50 lb ...
Kreigers,Vas es los(what is that stuff )
Sorry, Jon knows -- Its a local scrapyard in Rochester ... ... Sorry its not the secret lubricant ..
