Where can I get the repoped Carter AFB air horns???????
#172473
12/21/08 06:26 PM
12/21/08 06:26 PM
Posts: 5,796 minnarusta
TX9H6E4CUDA
minnarusta
So where can I get them? I heard they repoped them so they can fit on the current generation of edlebrock carbs? So who makes them?
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: Where can I get the repoped Carter AFB air horns???
[Re: mickm]
#172476
12/23/08 03:44 AM
12/23/08 03:44 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Phil Newcomb of Hemispherical Productions (SLC Utah, formerly in S. CA) had them made, they are easy to ID as they have "HP" cast into the top (his company initials). They do not look exact to originals in either shape or finish but are close enough for clones. I do not know if he sells them sepperately, I think he only offers them as complete clones only, I've never tried to order any because I just find good used originals to use as cores for my Hemi clone carbs. If you are building Hemi clone carbs you'll need correct tops as well as correct side linkage which is Hemi only, the factory welded these on to the shafts (as I do), so making clones is doable for a "Do It Yourselfer" but it's not a simple top swap, nuts and bolts deal as many might imagine. I will tell you this much, he and I are on good terms and have met and talked at length multiple times (consider us to be friends if you will) and even at that it's usually absalute murder to get him to ship anything you order, even after multiple promises (and failures) of doing so. I just don't know what his deal is anymore, I like the guy but he is probably the poorest communicator I know in the hobby......Just a fair warning! Here's a pic of what mine look like, this set has the optional electric choke
Re: Where can I get the repoped Carter AFB air horns???????
[Re: wino]
#172479
12/23/08 01:09 PM
12/23/08 01:09 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
thease carbs were used on a lot of 50's 60's cars buick,cad's etc.
This is true, in fact most of my core tops are GM in origin, it's almost manditory because Mopar didn't use many with the right configuration for non hemi applications, but as noted, it's not just the tops that you need to make Hemi clones, that is just the beginning.
[Re: BarrsRestoration]
#172486
12/30/08 11:00 PM
12/30/08 11:00 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
And how does one contact Mr. Newcomb?
I'd reccomend a new method since e-mails and phone calls never get returned...Maybe send him a teligram or possibly Pony Express?
[Re: ScottSmith_Harms]
#172489
12/30/08 11:25 PM
12/30/08 11:25 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Nevermind, I just tried searching his ebay name and came back as an unregistered user, huess he bailed on ebay too, his feedback record pretty much says why...
blinginhemi ( 1485) Not a registered user Positive Feedback (last 12 months):
Mopar 1970-71 426Hemi/440+6 Air Cleaner Splash Shield (#280279378857) US $9.95 View Item bankcheck,still held10 days,5 weeks to ship,turned into ebay doesnt reply emails Buyer: andrewsconstruction ( 331) Nov-12-08 12:56
Mopar 1967-69 A-Body 383/440 4bbl Auto Trans kickdown (#270274468941) US $129.95 View Item This comment has been removed by eBay. Learn more. Buyer: the-jersey-boy ( 143)
Nov-12-08 09:47
Mopar 1970,1971-4 Hurst Pistol Grip, Cuda/Challenger (#280275173751) US $494.23 View Item Slow shipping no reply to polite email only responded when dispute opened Buyer: jimshea ( 635) Nov-09-08 06:10 Reply by blinginhemi (Nov-09-08 17:06): LIER, HOPE HE DOESN'T BID & WIN ON YOUR ITEM! HE IS WHATS WRONG WITH EBAY-BITTER Follow-up by jimshea (Nov-09-08 20:04): I can PROOVE to ANYONE That my dissapointment in you is valid your the liar
[Re: 62maxwgn]
#172493
12/31/08 12:25 PM
12/31/08 12:25 PM
I bought a couple of old Mopar AFB's on Epay with the correct tops and mounted them on new 9606 AFB's and they work great. You have to look carefully to make sure you get the correct tops though. Now I've got AFB parts everywhere. I used new carbs on this build so I got tight throttle shafts. Next time I'll just rebuild a set of old Mopar AFB's.
Sheldon
